Debayering images from an Atik 383L+ in nebulosity
9 replies365 views
Graham Kettlewell avatar
Hi all. I am trying out a CCD. I have been using a modded Canon 450 for a  few years now. I use Nebulosity 4 for my stacking and debayering.
I am trying out a borrowed Atik 383L+ colour camera.  It looks to me like the debayering mask is wrong. I get quite weird results if I use the default settings. I have found the preference window that allows you to set the mask. I can't seem to find the matrix information in a format that I can understand. Any ideas?
Graham Kettlewell
David McClain avatar
Hello Graham,
From the manual on the KAF-8300 it would appear to be GRBG.
http://www.ccd.com/pdf/ccd_8300.pdf
But you are at the mercy of the driver code, and my experience has been quite varied, even for the same camera sensor, but different makes of camera.
Best suggestion is to image something for which you know the color, then try all possible permutations until it looks correct.
David McClain
Well Written Helpful Insightful Respectful Concise Engaging Supportive
Thanks for that. I guess its time for some experimenting,
Graham
I have solved the mystery of debayering. Nebulosity can recongnise images take with the Canon 450D that I have been using until now. It doesn't recognise the images taken with the Atik 383L+. It prompts for input about how to debayer when this happens. I have to select RGB as the debayer method,  and offset the mask on the  x axis by 1 pixel to get the debayering correct. I just posted a shot of Horsehead and Flame taken with the Atik camera. I am reasonably happy at this point.  I will keep experimenting with my exposure times and workup to see what I can manage to get from the camera.
Thanks for your help.
Graham
pfile avatar
what software are you using to capture the images? the problem could be that nebulosity is reading the fits file upside-down with respect to how it was written out. offsetting by 1 pixel fixes that problem.
I used Nebulosity to capture the frames as well as to work them up, so it would be a bit unfortunate if this was the case.
pfile avatar
hmm, ok. i suppose then that by shifting it one pixel you're making the image look like it was RGGB (how canon cameras are bayered)…?
Robert Q. Kimball avatar
With the Atik 383L in PixInsight you should debayer using BGGR.  The best algorithm is VNG.
Bob
giange77 avatar
Dear Graham
I've just started using a Canon 450D (Badder modified) with Nebulosity. Initially I got wrong colors. I then selected Canon 20d or nodded Canon from the preference menu and seems to get better color debayering.
Were you using standerd Nebulosity settings or a manual configured Debayering matrix and offset. In which case can you please let me know?
Thanks
Gianluca
I have found that the mask differs with different capture software.  With Atik's Artemis I found BGGR worked.  When I switched to SGPro  I had to use GRBG .  I suggest you try all four options.  One will work.
Bob
smile
