Craig Dixon avatar
Hi All.
I have an issue tonight with dew on my L-enhance filter. This is a 1.25” filter screws into the adapter ring right in front of my ASI533MC Pro camera. I’ve tried clearing the dew with a hair dryer, which took just a second but the dew comes back. I’m not sure how I can deal with this really. Has anyone had this issue before?
Bruce Donzanti avatar
I let the dew dissipate on its own.  I never use a blow dryer as it can add dirt to the filter.  I’ve learned over the years that sometimes the best course of action is inaction.  This is one example of that, at least for me.
Well written Insightful Respectful Concise
Craig Dixon avatar
Ah ha. It’s disappeared on its own. Excellent. Thanks for the reply!
Well written Respectful
Can someone help me, bought a used RASA and unsure how to connect
Hi, I bought a used RASA, and there appears to be some kind of attachment to the front that I cannot connect to(see images). My understanding is that you use the camera adapter plate and a retaining ring to screw on the front. The scope appears to ha...
Discusses equipment connection issues; dew shield mentioned as relevant accessory.
Jul 15, 2025
Dew formation on 8" Newtonian primary mirror
I have a Skywatcher 200pds 8" Newtonian with a fan, dew shield and heater band for the secondary, which I need. This winter I have noticed dew forming on the primary past about 01:00 after observing since 19:00. Has anyone had the same problem a...
Different optical surface, but similar dew problem-solving strategies may apply.
Feb 3, 2022
Dew problem on coma corrector
I've ran into a dew problem on the front of my coma corrector when using my newt. My subs over the evening get blurry, and having ruled out clouds given the sky was clear, i saw dew on the coma corrector lens when looking through the secondary mi...
Addresses dew problems on optical surfaces; directly applicable solution.
Jan 7, 2022
Rings in image?
Refractor: 103APO, Camera: Canon EOS R6 I highly doubt its reflection rings because i have the dew shield extended, the camera doesnt emit light when shooting either. Been having this issue for a year, not sure if it could be the reducer or the teles...
Addresses dew shield usage and optical issues with imaging setup.
May 12, 2025
Help setting up Backfocus on Epsilon-180 with ZWO OAG and EFW
Hi, I am looking to dial the right backfocus for my setup. I am using ZWO ASI2600MM on my epsilon with ZWO EFW and OAG-L. The entire setup comes to around 56.7. Here’s the connection and respective spacing in mm. Camera (12.5) -> EFW(20) -> OAG...
ZWO camera setup optimization similar to author's ASI533MC Pro camera.
Apr 17, 2025
