GraXpert 2.0 and PixInsight Script
Frank Sackenheimschmellyandrea tasselliBob LockwoodJoël VALLIER
154 replies13k views
Frank Sackenheim avatar
Hello,
I am Frank, founder of the GraXpert Team. Our Team has now officially released the Version 2.0 with AI functionality. Also GraXpert AI is now available as a script in PixInsight, so you can use it directly out of PI.
I have created a video to show you the installation on Mac and PC, as well as the installation of the script.
Have Fun
https://youtu.be/7u6jIlmPZh8?si=7jYfx0ED3_JLzwL0
Frank and the GraXpert Team
Abdul Thomas Jnr avatar
This script is such a big upgrade compared to the PixInsight DBE. Well done to you and rest of the team 👏🏽
Jared Holloway avatar
Been waiting for this, thank you!
Bruce Donzanti avatar
I could not get it to work within PI.  I can get it to open outside of PI but even after I added the link in your video, I get an error message- You must setup the path to GraxPert first using the wrench icon.
Bruce Donzanti:
Hi, yes i showed this in the video how to setup the path using the wrench icon.
CS Frank
Thanks, Frank.  But I now have another problem.  I followed your direction about the wrench, it started to open and then froze.   I did have the older version on PI before but I removed it before starting over.   After trying to close it, the GraXpert icon remained on my computer and I had to reboot to remove it.
Bruce Donzanti:
Not sure if I got you. You are saying you PI Version is older? We cant´t be sure that the script works well with older versions. Try to update PI and try again. If this doesnt work, i will forward it to the developers. Hope thats ok for you.
Cheers
Frank
No- PI is up to date and runs just fine.  I deleted the older version of GraXpert labelled 2022.
Hi Bruce, I can see in the Console Window a message saying: AI Version not found. Did you follow exactly the steps in the Video from Top to Bottom? Please try again from the start, watch the video from the start and follow all instructions please. I think you have not downloaded the AI, which is mandatory. Its explained in the video.
Cheers
Frank
Hi Frank
OK- I started from the beginning and now it runs in PI and it appears to change/remove the gradient.  There is still one difference from your video that I am getting........
 It may be hard to read but I get a statement saying, "MainProcess tensorflow WARNING  No training configuration found in save file, so model was *not* compiled."
It then continues and does its thing.  I'm not sure if this is specific to my computer or if I did something else wrong.
I appreciate your patience.
Bruce
ScotiaAstro avatar
Frank Sackenheim:
Hello,
Have Fun
Bravo to you and the team, Frank!
Been using your new PI integration on my latest images and it's working beautifully...nice job!
Best wishes from Scotland,
Steve
John avatar
To bad it wont start  on macos catalina 10.15.7 . its a I7 with 32 gig ram.
 install was ok etc ,also the security settings  where done.
Bruce Donzanti:
I will ask the Developers, but I think its no big deal. As long as it works.
CS Frank
John:
Hi John,
can you give me a few more infos. Does Graxpert not start, do you get any message? Or does the PI Script not work?
CS Frank
Jeffery Richards avatar
Bruce Donzanti:
Bruce,
I am seeing the same thing. Will be interested in the reply from the developers.
CS Jeff
Ashraf AbuSara avatar
Jeffery Richards:
Bruce Donzanti:
Bruce,
CS Jeff
I get the same. It does not seem that the functionality is affected though. Background extraction seems to be performed as expected.
concerning that message: Just ignore it :-)
CS Frank
Frank Sackenheim:
CS Frank
Thank you so much for this amazing piece of software.
Spacetime Pictures avatar
This thing is a gamechanger imo
Thomas Rox avatar
Hi Frank,
thanks for all the effort you and the graxpert team have invested.
I followed your instructions and it works well and somehow magically.
I am interested in how it works with the AI part. I know that AI and machine learning are somehow black boxes, but it would be interesting to learn the principles of the learning process.
Unfortunately, I did not find any information. So, is there any documentation going into more details than saying AI is applied?
Any link will be welcome.
Thanks in advance
Thomas Rox
Respectful
Thomas Rox:
Hi Frank,
Thanks in advance
Thomas Rox
Hi Thomas,
we will update our documentation to fully explain what we did and which data we used. But thats all a lot of work. Hopefully we can do this until the end of the year.
Basically we did the following.
We used tensorflow as the framework for our AI, so thats a convolutional neural network.
We then used Graxpert in its former version to create images with and without gradients. In most cases we used the RBF algorithm, that was very sucessfully in GraXpert 1.0. We trained the network with those before and after images. So we can say, the network learned how to create backround models like the RBF algorithm does. As soon, as the AI creates the Model, its simply subtracted from the original image.
Thats how it works in a nutshell.
Cheers
Frank
John avatar
Frank Sackenheim:
John:
Hi John,
CS Frank
I installed the GraXpert-macos-x86_64.dmg
Just  the way you show on youtube, and its  installed correct . i did even reboot after,but when i click the icon,it pops for 1 second and then  it stops.
Did the install twice,still the same.
Thomas Rox avatar
Frank Sackenheim:
Thomas Rox:
Hi Frank,
Thanks in advance
Thomas Rox
Hi Thomas,
Cheers
Frank
Thanks. That gives a good first impression. I will have a look at your updated documentation.
Thomas
John:
Frank Sackenheim:
John:
Hi John,
CS Frank
Hi, I am afraid to tell you, that GraXpert works only from macOS 11.0
John avatar
Frank Sackenheim:
John:
Frank Sackenheim:
John:
Hi John,
CS Frank
ok thats  makes sense.  i will test it on windows.  but look a great tool to me. thank you.
