Eric Beckinger avatar
I'm having trouble with using flats to get flat images with a full frame sensor and 2 inch filters. Due to the large size of the of the sensor and the size of the image circle, the corners on my shots are significantly less illuminated than the center of the image. This seems to be causing trouble when using flats to get a flat image. I am having the most trouble with broadband filters and OIII specifically. HA and SII seems to come out flat regardless.
I use SGP to take my flats. In the past, I've used the flat wizard to take flats and get a centered mean ADU value. This works great if your sensor is not blocked in any way and the imaging circle illuminates all of the sensor. This method does not work if your sensor is not fully illuminated and the edges are significantly darker. I have found lower mean ADUs works great for HA, SII (~14k ADU). I have had a lot of difficulty with broadband filters.
I have gone through the process of taking flats with my filters at differing mean ADU values in increments of 1000. Depending on the exposure length of my light frames and how bright the target is, I have to select the best matching flat set. This is very tedious and I do not know of a method to calculate the best set of flats I will need.
For my testing, I've been using the batch pre-processing script in PixInsight to generate my stacked images. I am hoping there is some methodology or setting that can help me with the process of getting a flat image. Here are some images to illustrate my struggles:
Flat (B) ~10k ADU:
Light (B):
Light (HA):
HA always seems to come out looking flat after stacking using a 14K mean ADU on the flats.
I'd suggest to shoot flats with 2/3 of the histogram covered, given that you have scant illumination at the corners (something due to your optical train so nothing you can do about it). You need enough signal at the corners to have any hope of a decent flat and then it will still be hard I'm afraid. Myself I've never bothered with anything less than 1/2 of the histogram covered in my standard practice. Frankly I don't even understand why bother with scaled flats at all.
[deleted]
I had the same problem in the past, especially with broadband, some friends from Astrobin recommended me to raise the explosion time of the planes to 5 seconds while maintaining a medium range, it worked very well for me.Hope it can help.
CS Iñigo.
CS Iñigo.
.Thanks for the tip. How did you go about accomplishing this? You would need a light source but very faint. Any recommendations?
mjgood avatar
I have the same issue using a full frame camera as well... I found this post on how to adjust the flat using pixelmath. I was able to correct the dark corners out of my images..
https://www.cloudynights.com/topic/685094-tuning-flats-in-pixinsight-using-pixelmath-process/
hope this might help
[deleted]
Indeed, at the moment I use a very low-priced light sheet, it has three intensities but to attenuate it more I use the potentiometer on the heating tape. It is not perfect but it works, in the next few days I will receive the Artesky 250mm flat field generator, it is not cheap, but it calculates and memorizes the brightness of each filter.
Hannah avatar
Hi my first post on the site so forgive me if I have missed anything.
I am relatively new to astro imaging and use a SW200p with a full frame Canon 6D, and getting images similar to yours.
I have just replaced the M42 mount with a 2" to M48 unfortunately I have not been able to take any deep sky images since doing that but I do have this, which shows the improvement.
ZWO ASI094MC pro FLATS
Does anyone know what ADU to use to get good Flats with ZWO ASI094MC pro? my corners become white. nick
Discusses flat field correction issues with corners, directly relevant to white corner problem.
Jan 26, 2019
Filter size needed to get no vignetting at f4 using a qhy 163
Hi, I am thinking about getting an 8 inch imageing Newtonian at f 3.9 I have a qhy 163m and I know the chip sits back further in these than the zwo 1600 mm. My question is what size filter will cover my chip without vignetting, will a 31 mm work or d...
Addresses filter sizing issues with full frame sensors and vignetting problems.
Nov 11, 2019
