Hi, I hope this is the right forum/category
A couple of days ago i made a post on Reddit about my field flattener not flattening the field properly.
I have since then tried pretty much everything, yet the corners and sides all have elongated stars. I can put as much as 60mm (the flattener requires 55mm +-2mm) of distance between the field flattener and my camera without the stars changing shape. I have tried with a bahtinov mask aswell, where all 4 of the corners have stars that have the vertical light streak to the left of the "X". No matter at what distance the camera is from the field flattener.
I found a post of another person having the same problem, and it ended up being the field flattener. It was bought used and apparently not working. They bought a new one, and the corners were then immediately sharp.
Imgur link with some photos with my setup: https://imgur.com/a/cNEkpKB
Optical train: TS-Optics 70/420mm doublet -> OVL field flattener -> Astroessentials t-ring -> Canon 600D.
If you guys have any input, i'd be really happy. Thanks in advance.
