Hi all,
My current setup is a 10" Newton on a EQ6-R mount which works perfectly well. Now, I'm wondering if it would be possible to attach my widefield setup (Samyang 135 + Nikon D3300) to the scope as well. So, instead of mounting only the guide scope onto the main scope, I could attach the Skywatcher L-bracket (that came with my Sky Adventurer) that could then in turn hold both the guidescope and the widefield setup. Even with that I would not exceed the 20 kg weight limit of the mount (but only by a few grams
Assuming I had two cameras, could I (as an example) point the scope and the guidescope at the Orion Nebula, while my widefield setup images the heart & soul nebula region. Guiding should actually work for both objects and the Orion region should be the better target for the guidescope as it has a lower declination than the Cassiopeia region. So, one could image two targets in parallel like that.
Is it that easy or am I missing anything?
Steve
Steve
