dvb avatar
Hi all,Wondering if you can help me sort out these comb-like streaks in the Ha data I’ve collected on the Pacman.I’ve not seen these streaks on any other Pacman I’ve searched for on-line, so I am assuming it is not data but some kind of artifact. If it is data, I will leave it in. But if it is an artifact, I will try to process it out, but I can’t figure out what is causing it.I have used the gear in question many times and have not seen it before or since, but it is on all the Ha subs of the Pacman taken over two different nights, Oct 6 & Oct 13.The subs are 300” long, taken with a Vixen 200mm f/4 with Nexus 0.73 reducer, so 600mm f/3, Baader f/3 Ha 3.5nm filter, ASI2600mm camera, ZWO AM5 mount.A few considerations:- The stars look fine, so the mount is not stalling
-  The subs from the OIII and SII filters are fine
-  Ha from other objects taken about the same time is fine, so I don't think is the filter
-  I don't think it's a light leak from its position in the frame, and I don't see it in any other uses.     Thansks!
Brian Puhl avatar
Looks like a reflection/diffraction spikes from a star outside of frame.   Shedar?   Mag 2 stars are no joke.
Insightful Concise
Tyrel Smith avatar
Brian Puhl:
+1 on this. Good catch Brian.
Graham McCullough avatar
Even if it is just diffraction from Shedar, it's still a really cool image.
Might This Be a Light Leak?
This streak is showing up on more than one filter, so it's not on the filters. I've had the cover/flip-flat wiped down, so it's not coming from there. Anyone know how to get rid of this? Though it seems to be calibrating out, I don't ...
Light leak could cause streaks; author already ruled out filters and flat.
Jun 12, 2025
[RCC] Streaky artifacts in M42 and request for critque
Hi everyone and greetings from Germany! I hope the awesome astrobin community can give me some help I recently processed data from M42 and i noticed two things: The stars at the edge of the picture are not roundThere are streaky artifacts all over th...
Streaky artifacts in astrophotography data similar to author's problem.
Feb 20, 2022
