Cristian Arhip avatar
Hello! I recently got the L-ultimate and I wonder if it is a good idea to make a trip to a bortle 2 zone and use it. Should I buy a uv/ir cut or I can use the L-ultimate? I have to mention I am not interested in capturing dark nebulae.
Gilmour Dickson avatar
I am fortunate to live and image under class 1 skies.  I use the L-ultimate a lot.
I have posted about this filter and dark skies and its usefulness on cloudynights a fair bit:
https://www.cloudynights.com/topic/873429-l-ultimate-filter-vs-l3-filter-bortle-1-skies-just-for-interest/
https://www.cloudynights.com/topic/874470-the-moon-vs-bortle-1-and-l-ultimate/
Cristian Arhip:
When I get the chance to get under B1&2 skies I'd probably gun for pure RGB otherwise what's the point. But, in the end, a filter such as the L-EXT will isolate those emission lines much better than would be the case otherwise for most emission nebulae, but not all.
BensAstroStuff avatar
You will get cleaner Ha/Oiii data with the filter, even in dark skies. So if you're going for those bands, it's very useful.
Well Written Concise
Thank you!
Clear skies!
patrice_so avatar
Well, you will get incredible data. Now, if I was to take the time to travel to a dark site, I would use the l-ultimate if the moon is out but focus on a nice broadband target if the moon is not there.
Patrice
Bob McInteer avatar
I've shot a lot of L-Ultimate at a zone that is Bortle 2 or 3. I find it very helpful when you shoot targets that can be overwhelmed by stars. Then you don't have to try to reduce them in processing nearly as much. In my system it's a hassle to remove the filter so I generally leave it in place. It does cut down the overall signal so things like polar alignment take a bit more exposure. When I (rarely) shoot from my Bortle 7 backyard it's super helpful dealing with the light pollution! Sometimes, but rarely, you'll find a target where it's a problem instead of a solution. The Pleiades and Triangulum Galaxy come to mind.
Helpful Concise Engaging
Yungshih Lee avatar
People often consider dual-band filters as light pollution filters, and many manufacturers promote them as such. They are actually two distinctively different things. Dual-band filters such as L-Ultimate only allow the bandwidth of Ha and OIII (or in some other cases, other emission lines such as SII) to go through and are really narrowband filters. The obvious example to explain why narrowband filters are different from light pollution ones is that many Hubble images are shot with narrowband filters and Hubble does not really suffer from much light pollution, at least if compared to the ground telescopes.
The purpose of narrowband filters is to reveal only signals of specific emission lines, not to prevent light pollution, even though they do have that effect. So the Bortle scale of a site is not relevant to whether a dual-band filter should be used, but rather what kind of target is being shot. L-Ultimate or L-eXtreme, etc. is generally only good for emission nebulae, or to add Ha, OIII signals to a broadband image. Using them on galaxies, reflective nebulae, dark nebulae, molecular clouds, etc. would give very poor results and could give inaccurate colors to stars and star clusters.
Bray Falls avatar
Yes it is a good idea, depending on the intended target. Especially with OSC and dual band filters you will have much better results
Ian McIntyre avatar
I'm bortle 4 with a strong gradient south and I swear by it as long as I have a target heavy in Ha and Oiii. When combined with NarrowbandNormalization in Pixinsight it's kind of a game changer. I would definitely still use it on trips to the bortle 1 desert. And as stated above it will offset moonlight as long as you are not pointed right at it.
Oscar H. avatar
NB is good especially if you are after faint planetaries
Yungshih Lee:
Very well said.  I get very tired of trying to explain to people who just say "bortle 1 means no narrowband filters".
New to astrophotography, and i appreciate your advice on what to buy!
Hello, I moved recently to a village in the north of Morocco, and it's pure dark here; you can see a lot of stars. I was always fascinated by the universe and the sky. I watch a lot of YouTube videos about astrophotography and am currently using an i...
Author moving to dark site, relevant to bortle 2 zone travel planning.
Nov 9, 2025
Would you replace the Built in UV/IR cut on a 2600MC with AR glass?
Hello All, I am looking to replace the built in UV/IR cut window on a 2600MC-Pro with AR window and using a better UV/IR cut filter with better cutoffs in the UV and IR (Baader cmos optimized UV/IR cut filter) so i get less UV and IR and better glass...
Directly discusses UV/IR cut filter options and replacements for imaging.
Sep 18, 2025
UV/IR needed?
I am wondering about the common wisdom of always using a UV/IR cut filter if shooting broadband OSC. I can understand its use with refractors that might not be well corrected at the extremes of a cameras sensitivity range but why do it with a reflect...
Directly addresses UV/IR cut filter necessity for OSC camera imaging.
Mar 23, 2025
Chroma Lo-Glow LP filter vs. Optolong L-Pro filter
I use Chroma filters but I often use the Optolong L-Pro instead of the Chroma L filter for LRGB captures under my Bortle 7 sky. I am curious if anyone is using the Chroma version of a LP filter, the Lo-Glow, and if they think it works well enough to ...
Discusses Optolong L-Ultimate filter performance; relevant for LP filter evaluation context.
Jan 14, 2022
