Johannes Teupen avatar
I recently started using the trial version of Pixinsight. I have already been able to integrate several scripts, but I failed to integrate Graxpert. Is that even possible and if so, how does it work?
I would be very happy about a tip.
CS Johannes
Harald Krause avatar
As far as I know, there is only the stand alone version
Albert Feuerstein avatar
I exported a 32bit tif, processed it in GraXpert and then opened the processed file in Pixinsight for futher processing
Randy Smith avatar
Yes, its stand alone.   Open your stacked master light in Graxpert, process it and save as XSIF and open it in PI.
[deleted]
If you install this package https://www.ideviceapps.de/PixInsight/Utilities/ they have added GraXpert under scripts/toolbox
Thanks [deleted], learned something new
Wolfgang Froehlich avatar
[deleted]:
But this is not the phantastic Beta-Version with AI yet, I presume?
Wolfgang Froehlich:
[deleted]:
The script just opens the Graxpert-Version  you have installed.
[deleted]
I had to download the latest beta version and ran it which in turn downloaded the AI files that GraXpert needed automatically, I then pointed PixInsight to the "GraXpert.exe" file and ran it on my image
Thanks [deleted] for your very helpful instructions, everything worked. Now I also have Graxpert integrated.
CS Johannes
Elias avatar
Let me add a little bit of insight to this:
The lastest version of GraXpert now supports a CMD-Mode.
That's exactly what the Script from Jürgens Utilities (https://www.ideviceapps.de/PixInsight/Utilities/) use.
It opens GraXpert via CMD and it then automatically launches a gradientremoval based on AI (only this is possible in the CMD-Mode).
After that the Script loads the processed image back in PixInsight.
If it does not support the CMD-Mode (aka you've got an old GraXpert version), it just open GraXpert normally.
If you want the convinient mode, with you setting the sample-points, you still need to open GraXpert outside of PixInsight.
andythilo avatar
[deleted]:
I downloaded that repository but have no toolbox
Jenafan avatar
You have to add the URL in PixInsight under the menu "Resources - Updates - Manage Repositories". The usual way to handle repositories. Finally the toolbox is located under Scripts - Utilities.
CS Jürgen (not the author of the script ;))
Concise
Albert Feuerstein:
=14px
I cannot save the master light edited in Graxpert as a xisf file, only with the suffix tiff.
Ian McIntyre avatar
Johannes Teupen:
Albert Feuerstein:
=14px
Once you open a tiff in PI you can save it as xisf.
Correction: I just loaded the repository and pointed to the graxpert app and it now saves in .xisf.
Zak Jones avatar
I have been very impressed with GraXpert AI. I think it does a better job at removing gradients than DBE/ABE, but yesterday the PixInsight developers announced their new project MARS (Multiscale All-Sky Reference Survey). I am interested to see how this new project will evolve over time and how it will perform, but for now I will continue to use GraXpert AI until it releases.
In relation to the forum post, I don't mind using the standalone app as it can save the corrected images as .xisf files which I can import to PixInsight to further process.
Zak smile
Well Written Insightful Respectful Concise Engaging
Steeve Body avatar
I have done that and nothing gets downloaded or installed.. the repository is completely empty
Jenafan avatar
Steeve Body:
did you "check for updates" after adding the repo?
btw. you need the latest PI version!
jose ortega avatar
receiving root error upon opening graxpert from within pixnsight2023-11-28 10:39:11,390 MainProcess root ERROR Traceback (most recent 2023-11-28 10:39:11,390 MainProcess root ERROR File2023-11-28 10:39:11,390 MainProcess root ERROR File2023-11-28 10:39:11,391 MainProcess root ERROR Filehelp…
Steeve Body avatar
Steeve Body:
I got it working now
Joël VALLIER avatar
Hi all,
Here is another script for GraXpert in PixInsight:
https://github.com/AstroDeepSky/GraXpert4PixInsight
Astrometric data are restored after gradient removal :-)
You have a full control of GraXpert options.
I need feedback on Linux plateform.
You can report issue in GitHub or put a star.
Enjoy Vega star release!
Kenneth Sabatini avatar
Hi all,  I've updated PI, Installed GraXpert4PixInsignt, updated the Repository, checked for updates, installed the updates, restarted PI, Run GraXpert from Scripts/Toolbox, pointed GraXpert to its Application, Run GraxPert .  I get the following...
Thoughts?
Joël VALLIER avatar
Problem reported by some others users on different systems.
For instance: https://github.com/Steffenhir/GraXpert/issues/65
You should have same problem when you run UI (I mean run GraXpert from MacOS not from PixInsight script).
GraXpert team is working on a new installable package with high priority but it takes time an delay next feature.
I'll keep you posted if I have some news.
Ah ok,  Thank you.
Nick Axaris avatar
All of a sudden Graxpert is refusing to start on my mac it was working perfectly until the last hour for no reason at all, despite restarting and despite reinstalling, it just hangs on startup I've done nothing differently
Sorted apprently GraXpert server was down so AI wasnt loading creating a feedback loop
