I use a Benq PD2700U. Is 4K, 27" IPS and for my taste, it has correct color representation. For the price, I think is a good option. If budget is not an issue, you may want to look at Eizo monitors.
It might not matter much which monitor you have if you calibrate that monitor. At least Windows has a color calibration function, and that can get you close if you work it a bit. If you really want to be precise, there are color calibrators (camera based) that you drape on your monitor, with their own software, to calibrate one or more monitors. You can find these on Amazon or other photo shops. I'd advise trying to calibrate before forking out $$ for a new monitor.
I agree that to calibrate the monitor is key, specially if the images produced are going to be shared, but I don't agree that any monitor is suitable for image processing (talking specifically about astrophotography). Wide viewing angle, for example is a must, in my opinion, and high resolution combined with big display allows to avoid busy workspaces (specially useful if processing with PixInsight).
Before I upgraded to a Dell P4317Q, I was using two LG 27UD68-W's. The point is you'll want a lot of space, so go for a wide monitor, many monitors, or even a large TV. At home I use a wide screen TV that I got off of Craigslist (can't remember make/model right now) for my computer monitor. For calibrating my monitor(s) I use a DataColor SpyderX Pro.
Hi All, I am really excited to be a part of the Astro-photography journey that I started a few weeks ago. I recently got a Star Adventurer Pro tracker (not 2i) and tried my hands on with it and was able to get comfortable with the wide-angle lens set...
Astrophotography equipment recommendations relevant to monitor selection for processing.
Well I never would have thought I’d consider going down the PI route 6 months ago but I’m seriously considering buying the software. My concern is my current computing power with my system right now. After reading PI’s recommended hardware suggestion...
Computer specifications for PixInsight processing software directly addresses monitor needs.
