Tilt correction in TS2600CP
3 replies•190 views
Mau_Bard avatar
Hi All, do you know if it is possible to correct sensor tilt with the TS2600? The 6 screws in front of the camera appear to me just fixing ones.
Many thanks in advance for your help.
Mau
Only with 3rd party hardware, afaik. Indeed the 6 screws aren't for tilting.
Mau_Bard avatar
Thank you Andrea, this is what I suspected as well.
Ciao, Mau
Mau_Bard avatar
Update: The TS2600-CP Generation 2, available from December 2023, with removable front plate, allows installing the OGMA Tilter https://getogma.com/products/OTIL26 , that can be operated from the rear, something that was natively possible only with the Player One cameras.
Matching sensor corners with subs corners
Hi there, I have a quite significant sensor tilt issue. Hopefully, I just saw a great thread on Cloudynights revealing that the M42 adapter plate delivered with my touptek ATR2600m can be used as a tilt adapter if one add 6 M2.5 grub screws. https://...
Directly addresses sensor tilt correction methods for astronomy cameras.
Sep 17, 2025
Tilt
I have sensor tilt and trying to get rid of it. I am really unsure of how to physically adjust my camera (ASI2600MC) to fix it. The good news I think is tilt is right where the adjuster bolt is. I have taken 5 images of M44 and shared a picture of wh...
Discusses sensor tilt adjustment specifically for ASI2600MC camera model.
Mar 16, 2025
