M33 Outer Dust Lanes vs. Sky Background
12 replies618 views
Steve Ludwig avatar
Dear community,
yesterday I acquired the second image with my new EQ6-R mount and chose M33 as target. I even got up at 2:50 in the morning to do a manual meridian flip, when the scope was only 10 minutes away from hitting the tripod.  In the end, I think it was worth it and I'm really happy with the result I got, especially the detail and star shapes (except in the extreme corners).
However, during processing I noticed that the outer dust lanes appear darker than the sky background. That is something I couldn't find in other M33 images on Astrobin, at least not in the maybe 25 images I looked at. Is that something you would consider to be real or might it be a processing artifact. I mean, actually it makes sense as the dust would of course absorb the background light. I didn't really touch the image a lot as the data was already pretty good. For example, I didn't use any masks to adjust certain aspects of the image. So, I tend to think it is real, as the darker patches all match with the slightly brownish dust patches.
What is your opinion? Did someone else notice the same?
Steve Ludwig avatar
Small addition: I just checked the background model image that was subtracted in the background extraction process. It looks normal, as you would expect it. It contains only the light pollution with vignetting towards the corners. No further structures in there. So, I can confirm that it is not a background extraction artifact.  smile
Well written Helpful Concise
Michael Timm avatar
Hi Steve, this effect is well known to me. It happens in two situations in my experience: When using the AutomatedBackgroundExtraction Process (which is always a bad idea) instead of the dynamic one. Or when choosing background points containing stars or other foreground information in DynamicBackgroundExtraction. Could one of these points be the cause? CS Michael
Edit: Just saw in your description that you used ABE. This is for sure the cause. You should use this process only for a first check if the image is okay, not for your final processing.
Steve Ludwig avatar
Michael Timm:
Hi Steve, this effect is well known to me. It happens in two situations in my experience: When using the AutomatedBackgroundExtraction Process (which is always a bad idea) instead of the dynamic one. Or when choosing background points containing stars or other foreground information in DynamicBackgroundExtraction. Could one of these points be the cause? CS MichaelEdit: Just saw in your description that you used ABE. This is for sure the cause. You should use this process only for a first check if the image is okay, not for your final processing.
Thank you for the hint. I normally use DBE as well, but lately I didn't had the time to do the time consuming manual sample placement. I will give it a try later today.
Michael Timm avatar
Good luck and CS to you!
Leonardo Landi avatar
ABE artifact for sure. Have a look at Visible Dark's tutorial about  easy DBE. The result is quite good!
Douwe79 avatar
I never use ABE for exactly this reason
Steve Ludwig avatar
you were all right, it was an artifact from the "automatic background extraction" process. I did another revision, carefully using the "dynamic background extraction process" which led to a much better result. I also tweak the color balance a bit.
Many thanks for your help identifying the root cause!
Best Regards
Steve
Well written Respectful Concise Supportive
Michael Timm avatar
Steve, glad you could solve the problem. The image looks good!
Douwe79 avatar
Indeed, looking good!
Wes Schwarz avatar
Steve Ludwig:
Hi,you were all right, it was an artifact from the "automatic background extraction" process. I did another revision, carefully using the "dynamic background extraction process" which led to a much better result. I also tweak the color balance a bit.
Best Regards
Steve
i have to disagree. The originsl image looked very natural. You have now just darkened the image so the surrounding structures cannot be seen. The first images had very slight background extraction artifacts in the darkest areas. The rest is natural dust in this heavily ifn laden region of the sky. IMO blackening the image out as you have done is a common amateur adjustment, I think it is common because it also makes it easy to hide other artifacts such as vignetting, ampglow, and noise from short integrations. Your first image was almost right on the money, if anything it just needed a more subtle pass with abe or dbe.
Steve Ludwig avatar
Wes Schwarz:
Steve Ludwig:
Best Regards
Steve
Hi Wes,
I didn't just darken it. I started to process it from the beginning, (carefully) using the DBE module this time. Feel free to brighten the image a bit to see the difference. The are no gradients towards the edges of the image anymore. I think I can also confirm that the things I saw in the first image revision really came from the ABE process. As soon as I placed the samples manually in the dark regions only (without including some stars like in the ABE process), I got rid of the gradients. However, in the end it sometimes is very difficult to "know" where to place the DBE samples. Dependent on the choice, the image will look different afterwards. So, I think in the end its more about personal taste.
ABE artifact. Wrong function degree that's for sure. ABE is an exceptional tool, but you have to choose the right function degree.
0 if you have an uniform gradient
1 for a linear gradient
2 for circular gradients.
Another source of tracking error... tires!
Hi Folks, Over the past month, I have seemed to notice that my mount's unguided ability didn't seem quite up to par. Over the course of the evening, the target would very slowly shift out of the center of the field of view. I noticed that if ...
Mount tracking issues could affect image quality and star shapes observed.
Jun 25, 2022
