deleted avatar
Does anybody of you have a wobbly Star Adventurer (Pro) ?
My wedge feels very unsturdy. It wobbles and shakes and even the screw for aligning the EQ feels loose.
See video for reference:
https://www.youtube.com/watch?v=mxrfYt2tZPI
8472 avatar
The wedge is very poorly constructed.
There are a pair of extremely cheap looking plastic washers/shims which hold the latitude plate to the lower half of the unit.
If you can, i would suggest unbolting this part and replacing them with metal disks of the same dimensions.
This mod alone increases friction and improves the setup no end.
I also replaced my base azimuth Hex bolts with wingbolts, as the hex key is easily lost in the dark.
Marc Agostini avatar
If you can, i would suggest unbolting this part and replacing them with metal disks of the same dimensions.This mod alone increases friction and improves the setup no end.
Good advice! Also crank down this altitude wrench, otherwise you will always have play in altitude. Crank it down so you can just turn the altitude knob without using excessive force.
Marc V avatar
Hi! I added another plastic shim and it is already more stable!
Clearskies!
Marc V avatar
Hi All!
[deleted]
Just a follow-up on my post 2 days ago : Last night I was finaly able to test my SA with this new shim added (thanks to the clouds) and it is definitly a hit! My rig is closed to be to heavy for the Star Adventurer (4kg). Before this addition, the alt level when pointing on Polaris was quiet unstable, but now it kept the alt for an hour easily. Very happy with this modification!
Clear sky, Marc
Polar Alignment with Star Adventurer 2 w/o Polaris in sight for DSO Imaging
Hi All, Hope you all are doing well. I am planning on testing my equipment at home from where the view to Polaris is blocked. The equipment I have is: Sony A7III ZWO Guide Scope and Camera Star Adventurer 2 Stellarmate OS on RPi4 w/ EKOS/KStars and P...
Discusses Star Adventurer polar alignment and setup issues directly relevant.
Jul 21, 2022
