Star Adventurer GTi with ASI air plus
2 replies196 views
Kevin McAskin avatar
I just got my ASI air plus today and was first using it. I ran into an issue with go to features, as even tho I was polar aligned and plate solved my mount was all over the place trying to get to the target. The issue I think it is is the mount being in Daylight Savings Time but the ASI air being in standard time, as it doesn’t support DST. It says in the app to set the mounts time to DST using a HC, but I don’t have one of those. Is there another way to change the mounts time? Has anyone else had this issue?
Johannes Maximilian Möslein avatar
You can set the time for the mount in the mount settings of the AIR.
Also, make sure your mount is in proper home position when you turn it on, otherwise it may get confused with directions.
Well written Concise
Jens avatar
I just had the same problem. I got this combination very recently too.
Did you use the built in tool from the asi air to polar align? Using that solved my problems out of some reason.
I thought it was the daylight savings too but in my case it wasn't the problem.
What you could try if that is the problem, is to change the actuall time of the phone to what it is supposed to be for the asi air.
Polar Alignment using ZWO AM5N /ASI Air Plate Solving
Hi I live in high rise Apartment with access only to Southern and South Eastern skies. With no direct visibility to Polaris or Northern skies, I end up doing using the Polar Alignment using their 3 Image technique using Plate Solving of ASI Air under...
Polar alignment issues with ASI Air plate solving relevant to mount positioning problems.
Apr 15, 2025
Struggling to guide my Star Adventurer GTi
Hello the setup i have used is - Star adventurer GTI - asiair mini - Svbony 165 and - Asi 120mm Mini but i had lot of issue during my first guide night my polar alignment was that: https://i.imgur.com/pDnzSNA.png but still lot of issue with the calib...
Star Adventurer GTi with ASI Air Mini guiding issues similar to your mount problems.
May 3, 2025
