Dotted diffraction spikes
10 replies535 views
Piers Palmer avatar
I seem to be getting rainbow/dotted diffraction spikes when I shoot with my 8" Newt. I don't recall seeing them before and I can't spot the effect in the individual frames. Is it just down to my processing?
They don't bother me in the slightest, I'm just curious!
Ruediger avatar
Hello Piers,
diffraction is wavelength dependent. Hence the different waves produce at different places minima and maxima. That's what you see. The geometry is given by the geometry of the spider vanes.
RÜdiger
Piers Palmer avatar
Thanks - I get the geometry (I rather like it!) but couldn't fathom why they were appearing "rainbowy". So it's just a result of how light works then!
Brian Puhl avatar
Thicker vanes produce that.  Thinner vanes will be far less 'dotted' or rainbowy.
Piers Palmer avatar
Ah well, the R200SS has girders for vanes so that makes sense!
Nick Grundy avatar
I was getting this on my epsilon 160 and didn't really think of it until now. thanks for sharing!
It doesn't matter the thickness as long it is an of order of magnitude greater than the wavelength of light. Mine are 0.5mm thick and they produce the same effect as well.
Nick Grundy avatar
All, are there any processing tricks to minimize the rainbow banding on the diffraction spikes in question? (just now processing and can't stop seeing them)
christianhanke avatar
there is a freeware tool available to calculate diffraction effects. Spherofront.
I did some studies with that. The thinner the spider vanes are the less pronounced is the rainbow in the spikes. The Takahashis have relatively thick vanes. My newton has very thin vanes and the effect is barely visible. The other solution are curved vanes.
I don´t think there is a processing solution to get rid of the coluered spikes.
Erik Frank avatar
you can avoid the spikes by a special spider mask, like i used in this image here: https://www.astrobin.com/tgvhai/
but the mask produces larger stars, because the energy of the spider have to be distributed somewhere in the image.
blackrig avatar
With narrow band you get separated dots. As you increase the band width, the dots connect to an almost continuous line once you get to full band.
The thicker the vanes, the more visible it is. You get the worst (most visible) with double vanes like in the Asa Newtonians, or other double vane scopes, like my home made newtonian
Also you need bright stars to see the effect strongly.
Last diffraction spike can be remove at processing.  Here is a way to doit which has received very little attention by the processing community, although it has been around for almost 5 years now.
Super Sample Anti Aliasing aware Registration and Stacking
Here to document a technique I'm working on for improving the quality of image stacking especially from CFA/Bayer camera images. In images, the overlapping of pixels on other pixels causes a pattern called Moiré interference. This can be seen opt...
Image stacking and processing techniques may introduce diffraction spike artifacts.
Apr 28, 2025
