Upgrading the focuser on an 8" RC
Flemming Kristensen avatar
This otherwise fine and popular scope's weakest link is its focuser, I think.
After a lot of problems I decided to upgrade to a much better focuser from Baader Planetarium. I have documented the process in a video where I also show how you can align the focuser perfectly with the optical axis of the primary mirror.
If you are interested you may find the video here: https://youtu.be/1logCewVcpI
Best regards,
Flemming
Gustav Lundby avatar
Luckily I did see this problem before buying and managed to make vendor do the swap against the cost difference.
I got the Teleskop-Express: TS-Optics 2,5" Zahntrieb Okularauszug mit M90x1 Anschluss und 360° Rotation . It allows me to place the flattener/reducer inside the focuser.  I did not have to correct the direction of the focuser. I have a M90 tilt in front, but have not had to adjust it.
Gustav Lundby:
Yes, that is also an ok focuser. It is mechanically identical to the one I have on my 94mm EDPH refractor, and works fine. It does feel a little bit springy, though, and not quite as responsive as the Diamond Steeltrack. That's fair enough considering the price difference.
Jamie avatar
Flemming Kristensen:
That's the same one I got for my TPO RC6 and love it.
Unable to achieve focus after reflector modifications
So last week I received my new spider, primary mask and rear plate(?) off AliExpress (link for reference - https://www.aliexpre....51d31802lnldIB) for my Sky Watcher Quattro 250P F4 My steps so far as follows: I installed the spider and mounted the s...
Author upgraded focuser; candidate discusses focus problems after modifications.
Aug 10, 2025
Telescope Configuration & Back Focus Manager
Over the years, my collection of telescopes and accessories has grown, and so has my obsession with getting every configuration just right. Whether I’m switching between deep sky and planetary imaging or experimenting with new gear, I realized one th...
Author aligned focuser with optical axis; candidate manages telescope configurations.
Feb 9, 2025
