Enrique Ojeda avatar
Hello Everyone!
I would be very grateful if you could help me with the stars in my image please. As you may notice, blue stars are not completely blue, in the center they look like yellow. Others have one part blue and the other yellow and some that should be blue only have a blue dot and the rest yellow or white. I don't know if it is a problem in my setup or in my processing or in both ='(. My setup is: William Optics FLT91, Hotech flattener, ZWO filter wheel, ZWO LRGB filters and Atik 414 ex mono camera. The image is composed of 20 x 300 for RGB and 120 x 300 for L (Drizzel integration), in addition to Darks, Bias and Flats (Sky Bortle 2). The camera temperature at 5°C. I did not use any additional filter. The processing is in PixInsight. As I see the problem is only with the blue stars. I have already tried several color calibration methods but without success. In the RGB master, before performing the color calibration, I can see the detail in the blue stars that I mentioned, which makes me think that maybe it's my Set Up. The truth is I don't have much experience that's why I come to you. I have already investigated possible solutions but without success. Thank you very much!
Helpful Respectful Engaging
Sean Mc avatar
Is this a brand new scope?
Difficult to say without accessing the raw RGB frames but I expect LCA being the culprit.
Sean Mc:
WO has been selling it for almost 3 years. Thank you
LCA? Is it a PixInsight process? Thank you
Sean Mc avatar
You also have star spikes. Did you add those?  If not, I ‘d say the scope either needs to be fixed or returned.  The aberration is affecting all the stars.
Sean Mc:
Hello! The spikes are natural, I didn't add them. Is that bad in a triplet refractor? I also have an ZWO ASI 1600 mono and I use it with a WO reducer flattener and I don't get spikes. They only come out when I use the tube with the Hotech flattener and the Atik 414 EX. I'll ask William Optics and see what they tell me. Thank you.ur reply here ***
Sean Mc avatar
They are hopefully going to ask for some pics. Take off the flattener and shoot a few at zenith and slewed east and west. That will also rule out the flattener. I returned two flt91’s.  for the money, the stars should be small and virtually perfect.
Sean Mc:
My tube is still in the warranty period. I'll do the tests you mention...I think maybe it could be the Hotech flattener. Anyway I will contact WO. One question: when I shoot in narrow band I don't have this problem, but I don't know if this detail doesn't appear due to the type of filters. Thank you for your comments. Clear skies.
Sean Mc avatar
You might not notice CA in narrowband single images, but when you combine rgb, you’ll notice.  See what happens without the flattener, you have to start ruling things out now. The camera you’re using seems to have very large pixels so it should be way more forgiving than something like an asi2600.
Sean Mc:
Thanks a lot Sean! Clear skies!
Rich Sky avatar
Perhaps, a focus problem followed by stacking method. RGB Channels mis-alignment, or curvature caused by filter or scope.
All need to be investigated. Good luck.
Enrique Ojeda:
LCA stands for Lateral Color Aberration, the variation of focal length with wavelength and field angle. However, in your case, it seems pretty constant across the field so it is unlikely to come from the main objective. Some other refractive components must be adding this.
Well written Insightful Concise
Rich Sky:
Thanks a lot Rich. Clear skies!
Enrique Ojeda:
Thanks a lot Andrea. Clear skies!
Marc Monarcha avatar
Not sure what the problem is but fix it quick! Your picture is looking absolutely stunning
Marc Monarcha:
Thanks a lot Marc!
Johnny Qiu avatar
It looks like it is because the stars from R/G/B channels have different aberration so they don't exactly align. It may be caused by the optical system itself. But sometimes it can be improved by acquisition strategy. For example, I am using parfocal LRGB filters and don't redo auto focus when switching filters. Then I loop RGB instead of taking them separately during different time. If you take R then G then B, during different hours / days, they may have slight different / imprecise focus which causes the aberration on different orientations. Seeing, guiding and wind may also vary. If you loop RGB with parfocal filters, these difference can be averaged out.
Johnny Qiu:
Very interesting! I get the RGB separately and yes, I think I took at least one of them on another night. I also refocus every time I change the filter. I am going to test all the suggestions that everyone who has commented here has kindly given me. I hope the culprit isn't my tube! Thank you and clear skies, without wind, without moon and with good seeing!
Respectful Supportive
Sean Mc avatar
Do you have or can you borrow a color camera to try on the scope?  That will rule out LCA due to stacking if you have aberration in one image. Unfortunately both of my returned scopes showed this in single color images.  I wish you luck too!
Supportive
Sean Mc:
Yes I have a DSLR. I will try your suggestion. Thank you so much. Clear skies!
Well written Respectful
Joon Ren avatar
Looks like chromatic aberration from the scope. Its fixable in post-processing by running something like Star Alignment in Pixinsight to remove slight differences and distortions between the R, G and B frames.  There's a fast tutorial here https://www.youtube.com/watch?v=UCKoJ1ticHI
Joon Ren:
I really appreciate your help Joon. I see it right now! It is truly a blessing to have this platform to ask for support and even better to have people like you and those who have helped me with their suggestions. Blessings to all and what better than clear skies!
Problems generating my flats
Hi! Does anyone know why my flats shots have two circles in the center of the image? My equipment is a WO RedCat v3, and in the optical train I have a ZWO filter drawer, a filter wheel, and my ASI 294mm Pro camera. I have the filter drawer because I ...
Flat calibration issues can cause color fringing and uneven star coloration.
Aug 5, 2025
Flat Calibration Problem
Hi everyone, I'm having an issue with flats/calibration in my setup. My setup consists of a Carbon TS Newton 200/800 with Starizona Nexus (effectively 200/600), QHY ImageTrain (QHY 268M with QHY CFW), and AstroWanderer Rotator. A screenshot from ...
Flat calibration problems directly relate to star color and processing artifacts.
Mar 11, 2025
