Filter question ...
4 replies172 views
danbi avatar
Filter question: I have an astronomik h-alpha 12 nm filter for use with my (unmodified) canon 70d dslr camera. Will this work with my asiair mini? or will everything be so dark that the guide camera wont be able to see enough stars for polar aligning and plate solving.
Thx for reading.
Rodrigo Roesch avatar
Most likely it won’t work since most of the Ha will be rejected by the stock filter that is in front of the sensor. So the small amount of Ha that passes will also depend on what telescope you are using, but also will require longer exposures. You may want to do your Pa without the filter, but focusing with the Ha on may be a challenge.
Sean Mc avatar
I say give it a try. It’s a full moon so you have nothing to lose.
Bob Lockwood avatar
Not that I would know, but a 12nm Ha is about as light as they get, you may be surprised what will pass through it.
Try it, and if it works, your good to go.
Oscar H. avatar
Firstly, unless you are using an OAG, the guide camera is unrelated to your main telescope; that means a NB filter would not affect guiding performance for the guide camera. Secondly, and most importantly, It's not a good idea to use an H-a specific filter or even a broader dual narrowband filter like an L-enhance with a stock DSLR (stock means unmodified). The built in IR filter of the unmodded DSLR will block most of the Ha from coming through.
Read this forum post and thread https://www.cloudynights.com/topic/845755-filter-ideas-for-a-stock-dslr/#:~:text=A%20narrowband%20filter%20will%20not,the%20Ha%20from%20coming%20through.
Planetary Imaging Setup and Prep
Finally finding some time to get back to imaging and have been focusing on getting my planetary routine set. I've ran into some frustrating challenges along the way and wanted to see how others have overcome these things and maybe learn something...
Planetary imaging setup differs from narrowband filter compatibility issues.
Apr 24, 2025
Polar alignment produces absurd correction angles
Hi, I am using an ASIAir Mini with a Skywatcher EQ AL55i mount connected via the serial cable (could not get any other connection to work properly). I can control the mount from the ASIAir app and I got my camera and focus set up. Plate solving works...
Uses ASIAir Mini; discusses polar alignment and plate solving problems.
Aug 18, 2025
Plate Solving Issues With New Antila ALP-T 3nm Duoband Filter
Hi Folks, I haven't found much on the internet about this issue. I posted on CN this morning and I am waiting for a response. I am using an Explore Scientific ED102 Essential Series scope with a 0.8 FR/FF so the scope is operating at F5.6 at 571m...
Narrowband filter plate solving issues directly parallel your H-alpha filter concern.
Feb 28, 2025
NB Filter Bandwidth Requirements for Galaxy Imaging - AND- Announcing the Galaxy Studio on AIC
A question that comes up every once in a while around here is what narrow band filter to use for adding Ha to Galaxy images? The concern is that as galaxies get further away, their light becomes more red-shifted so the question is how well will 3 nm,...
Narrowband filter bandwidth requirements relevant to your H-alpha filter application.
Jul 6, 2025
