Voltage for my astro equipment, is it to high?
12 replies372 views
Daniel Renner avatar
Im currently building my own powerbank using a 12v 100ah ifepo4 battery. In my pegasus powerbox software it shows 12.9 volt , is that OK or will it damage my equipment?
(Usually when I run my equipment using mains power it shows 12.7-12.9 also)
I have read that astro gear can benefit of alittle higher voltage, but I want to know what you think about that.
If it's not safe I'm going to buy a 12v supply regulator.
Ryan Génier avatar
Shouldn’t be a problem. Most equipment has a wide input voltage tolerance.
Jeff Reitzel avatar
Pegasus Power Boxes have an input voltage range of 11.0v to 14.5v so it is not an issue for you.
Jeff
Concise
t-ara-fan avatar
I run EVERYTHING at 13.8V. ZWO cameras, A-P mount, EQ6-R mount, Focuslynx, dew heaters, 12V rated USB hub.
Linwood Ferguson avatar
"12v" is a class of devices but it has historically applied to lead acid voltages in cars, which are in the 12-13 range normally and about 13.8 (maybe a bit more) charging.  Anything labeled for "12v" is designed accordingly since so many people still that way.  LiFePO4 may be a bit higher.  I wouldn't worry until you are above about 14.5 as mentioned above.
Actual 12v supplies are actually a problem, i.e. that put out 12v.  The tiny wires and poor connectors on many astro rigs mean that by the time it gets to the load it's in the 11.x range, which may be too low.
David avatar
Connected equipment should provide a power specification in the users manual, e.g. 13.8V +/- 10%  (12.4-15.18V). Non-LiFePO4 batteries when fully charged could have voltages much too high (16V+) which may damage equipment. I use Ryobi 18V power tool batteries with a golf cart voltage regulator which reduces 18V to 13.8V, to power the mount. The regulator can also increase low voltages (8-40V input).
https://www.amazon.com.au/Converter-13-8V-Automatic-Waterproof-Transformer/dp/B07X9Y5MXT?th=1
thank you all for the answers! =)
Timothy Prospero avatar
*I do the same 13.8VDC
do you use a device that stepps up the voltage?
Daniel Renner:
I use a power supply that allows me to adjust the voltage from 11 to 14 VDC. I've set it to 13.8VDC. There's a version similar to the 10micron, but you can find more affordable options from other suppliers.
https://www.conrad.it/it/p/ea-elektro-automatik-ea-ps-512-21-t-alimentatore-da-laboratorio-a-tensione-fissa-11-14-v-dc-21-a-300-w-num-uscite-510105.html?source=googleps&vat=true&utm_source=google&utm_medium=surfaces&utm_campaign=shopping-feed&utm_content=free-google-shopping-clicks&utm_term=510105&gclid=Cj0KCQjw06-oBhC6ARIsAGuzdw15GcUm4-S0fbc4mCGgrhAyIQO3k8vD-R7Hy3xlVbCIsYfqJTECk5caAkkvEALw_wcB
LookSpaceThings avatar
For the record, I have the oposite "issue". My voltage is always below 12V. Most of the time on 11.5V but in one night it was 10.8V. Everything was still running fine.
Arun H avatar
You can check the actual voltage specifications from the manufacturer and most will respond. My power supply is set at 14.1 Volts.
I verfied that the ZWO cameras, my focuser, and my mount can all handle this voltage.
Linwood is correct that setting things at exactly 12V could result in insufficient voltage problems especially with thin wires and long cable runs. There is a reason electricity is transmitted at high voltage - I^2R losses are much lower  at high voltage and safety is addressed by stepping down closer to the point of use.
LookSpaceThings:
You should fix that, as at some point it won't run fine, you will have mystery problems sporadically that you will chase, thinking it is a bad cable or software bugs.  Eventually.
Power issues!
Hi all, I'm having some issues with powering my astro gear. Whenever current draw is high (like when cooling camera), my input voltage gradually drops until it is near 10.5V. Obviously, this is not ideal for the equipment, but simply purchasing a...
Addresses voltage drop issues during high current draw situations with astro gear.
Apr 8, 2025
Power supply for astro imaging
Hi all, I'm looking for suggestions regarding a good quality power supply for my astro imaging equipment. I've realised that if I had a power supply failure due to high voltage output (which I have happened in the past with different equipmen...
Directly relevant - discusses power supply selection for astro imaging equipment.
Mar 15, 2025
Power Station for occasional use
Hello all, I know this topic comes up a lot, but i’m trying to consolidate my research with a few opinions of those who might be in the same boat as me. My normal set up at the moment is a SA GTi mount, with a REDCAT 51, ASI533MC Pro, filter wheel, E...
Covers power station options for astro equipment, similar DIY power solution approach.
Aug 31, 2025
