Pixinsight Workflow Suggestion
4 replies310 views
Naiteek Vikamsey avatar
I have been OSC imager since 8 years and now i am switching to Monochrome camera with full broadband and narrowband filters set
I have always looked to retain the original color balance of the object. Now with the use of SHO narrowband filters how am i suppose to retain orginal color tones? I m not interested in producing the hubble palette and any such false color images
What would be the correct way to map SHO to RGB channels?
S2 + Ha —— R Channel
O III —— G and B Channels
Is it correct?
Not sure why you would want to do that. If you're aiming at HOO you don't need SII so you can spare that time to get more integration in the OIII and H-a channels, especially the OIII which is usually the weaker of the two (except for PNs, that is).  Otherwise, yes, that's correct in principle. Not sure what you mean by the other question.
Makes sense to get only Ha and OIII… But many objects do have a very strong SII signals, like the eagle nebula etc. So in that case what to do? And i have seen people mapping some Ha data into B channel as well along with R channel to make it appear pinkish, how about that?
I'm not sure there are too many of them in the emission nebulae category, from what I've tested so far. So maybe M16 is the exception to the rule (since Sulfur is much less abundant than H, being only the 10th most abundant element in the Universe with O being 3rd). There are loads of different takes out there so feel free but then it isn't anywhere close to "natural" colors.If you want to retain a pinkish hue to the a nebula the right way is to add H-beta to the B channel (there other emission lines as well but they are much much weaker). In some instances H-alpha can act as a "proxy" for H-beta so I can see where they are coming from but I'd still go the "proper" way and use a H-Beta filter.
Ashraf AbuSara avatar
Yes you will need to blend the Sii data with the Ha data in the red channel. You might want to consider using the free Foraxx Palette Script. It utilizes and automates dynamic narrowband combinations with pixelmath. I believe it is closer to "natural" colors than straight SHO, especially for the star colors, and can be created from Ha / Oiii or Sii/Ha/Oiii data sets if you chose. Maybe give it a shot and see if you like the colors you are getting from it.
In the end it is difficult to produce "natural colors" based on pixel math formulas because every target is different, and the only "true color image" is an RGB image but that would lose all the benefits of narrowband imaging.
[RCC] NGC 7000
I created two versions of this image, one with fewer stars than the other and have otherwise been struggling with narrowband. I got this data from Telescope live and thought it should be a good test of basics so I thought id give it a go and ask you ...
Narrowband processing struggles; relevant experience with monochrome imaging techniques.
May 27, 2025
Which Filter set for Mono narrowband Imaging?
Hi there. I just aquired my first mono camera (ZWO ASI 585 MM pro) and i made the mistake to buy the cheapest SHO narrowband filters possible (the SV227 filter set). I now suffer from severe haloing. Although other than the halos the filters are actu...
Directly addresses SHO filter selection and monochrome narrowband imaging setup.
Jul 22, 2025
Sadr edditing problem
I have tried editing my Sadr region several times now, but I keep failing at getting a satisfactory result in terms of color composition of this SHO data. Maybe someone in the community can manage and give me some pointers? https://www.dropbox.com/sc...
Discusses SHO color composition and editing challenges with narrowband data.
Aug 19, 2025
Astro pixel Processor - How to combine a OSC broadband image and Extracted Ha and OIII from a dualband filter?
Hello All, I have a 2600MC-pro and have been using APP for a couple of years. I normally am only using 1 filter so no issues stacking. APP has been great. Now I would now like to take broadband subs and add the Extracted Ha and OIII from my antlia AL...
Combines broadband and narrowband data processing with monochrome camera workflow.
Sep 5, 2025
