Anyone have any experience with the Nikon 200-500mm lens or perhaps camera lenses in general?
12 replies648 views
Benjamin DeHaven avatar
As I've gotten better at focusing and guiding I've come to realize that I'm getting seagull shaped stars in my corners. I normally shoot the Nikon 200-500mm lens wide open at f/5.6 with the Nikon D850, a full frame camera.
Here is a 200% zoom in the upper right corner of an unedited stack in Pixinsight. How far down might I need to stop down to get round stars? Anyone experience this with this lens or camera lenses in general? Just questions for a cloudy night when I cannot get out and try it... I really hope I don't have to go more than a stop to f/8 or things could get dicey... Thanks!
Benjamin
Cody Looman avatar
I used a 600mm f4 for awhile. It suffered from pretty bad coma and had to be refocused constantly. If I stopped it down to f8 I saw a decrease in the coma but also a huge decrease in signal to noise.
Well written Concise
Cody Looman:
Ouch, 2 stops... stopping down to f11 would be very bad...  thanks for your experience!
NeilM avatar
I love my Nikon 200-500mm lens!  I mainly use it for wildlife photography on my  full frame D750 but I have  occasionally used it for astrophotography
I'm not sure if this will be helpful at all.... but ..  here is a 200% zoom at the corner of a recent image of mine with the 200-500mm lens and my D750 camera.  This might be a totally useless comparison in which case please discard this message and move on!  I shot this wide open (f5.6) but I spent at least 30-40 minutes trying to focus the darn thing.  Focus is the reason that I don't use this lens more often - the focus ring has a hair trigger!  I put  electrical tape on the focuser to ensure that I could only move in minuscule amounts.
Regards
Neil
Same lens here. I think you'll be better served using the lens in DX mode and as  @NeilM  states you need to be very careful during focusing and I'm using a rubber band to make sure I can get the small increments that needs to be used. This is my test shot (@ f/5.6):
Nikkor AF-S 200-500 f/5.6 ED Full Frame Test (andreatax) - Full resolution | AstroBin
privateer avatar
I wonder how that new Z 180-600 lens does in the corners. I might have to test.
Peter Graf avatar
I was also surprised when I tried the 200-500 (which I really like for daylight shooting) for astrophotography. With the D7200 (crop sensor) I can confirm the same shapes of the stars in the corners. Likewise with the Tamron 70-200 G2, which on the whole also works quite well.
However, with even smaller sensors it gets better, of course, for example with the ZWO Nikon F adapter and the 533MC-P. I have mounted the ZWO EAF on a wooden plate in such a way that with a toothed belt the autofocus works (comparable to the 3d-printed EAF adapters available for more common "astro" lenses). Unfortunately, there is really a lot of backlash, that you have to compensate, when you move the focus ring. Might be the same with manual focusing. And I have not stopped down and used f5.6 (otherwise I would have fiddled with unscrewing the lens from D7200 while powered on, and so on).
Conclusion for me: it works, but I don't know if I will use it regularly. ;-)
This is a single debayered and stretched light frame, top left corner at 200%. Optolong L-Pro filter, 300s, on iOptron GEM28 mount.
This is a combination of five of these light frames with some basic processing.
Joon Ren avatar
Maybe you could stop down for the stars but keeps the lens wide open for the main target? Then you can combine them both in post-processing.
Francesco Verardi avatar
Using photo lenses with a full frame hires camera like the 850 is not easy, in the past I got good results with a Canon 600 f/4 stopped down to 5.6 and an Aps-h camera.
Christian Koll avatar
Benjamin,
I started astrophotography in 2016 using the Nikon AF-S 200-500mm zoom lens and a Nikon D750 - I took a large number of images with it.
Examples of my pictures taken with this lens on Flickr:
https://www.flickr.com/photos/147135308@N08/40130260293
https://www.flickr.com/photos/147135308@N08/43406730451
https://www.flickr.com/photos/147135308@N08/39488308135
https://www.flickr.com/photos/147135308@N08/38460633215
https://www.flickr.com/photos/147135308@N08/34138676123
https://www.flickr.com/photos/147135308@N08/33734712116
https://www.flickr.com/photos/147135308@N08/29482364591
At which focal length did you take the picture from your original post?
I figured out that at the maximum focal length this lens has bad stars in the corners.
That's the reason I used this lens below 400mm focal length only. And yes, I used the lens wide open at f/5.6.
I also had the impression that the image quality of this lens deteriorated a little with time (and I definitely got more "picky" regarding star quality...).
That's the reason I finally switched over to a true telescope in 2020. Today, I only use the AF-S 200-500mm for daytime photography.
Best regards!
Chris
PS: Another tip when using this lens, you've probaly figured out already: Make shure to lock the zoom ring in place with some sticky tape, so your focal lentgh woun't change over your imaging session.
Yes, sorry, this was at the 500mm end of the zoom range.
Well written Respectful
Pavel Karas avatar
I am planning to do some tests on a starfield in the near future. I’ve had a chance to test it on the Moon and landscape and it looks very promising.
Up to 500 mm: very sharp even wide open. At 600 mm: a bit soft wide open but razor sharp between f/9 and f/11 (haven’t tested slower apertures).
Pavel Karas avatar
From my experience, it is hit or miss. Most camera lenses are not optimized for the infinity distance but rather for the distances they are most likely to be used at. Not to mention that stars are pretty specific type of object (very bright point source). When capturing stars, artefacts such as this coma are pretty common. This is true even for the telephoto lenses.
There are some models which perform exceptionally well, such as notoriously known Samyang 135mm f/2 (although there might be a slight inconsistency in the quality across manufactured pieces). I would love to hear about some more. :-)
Help me choose a Strainwave/Harmonic Mount!
Hey folks, Hope you're all having a great day out there! I'm on the hunt for a new portable mount for astro imaging with a range of gear, starting from a camera lens/dedicated camera combo right up to a small wide-field refractor and camera. ...
Discusses mount selection for astrophotography gear and imaging setups.
Apr 3, 2025
Looking for gear & accessories advice
I have recently got into astrophotography and use a stock Canon 7D mark II with 400mm f/5.6 and 50mm f/1.8 II. My circumstances don't let me spend more than 2/2.5 hours out photographing hence the amount of total exposure time I can manage is lim...
Addresses gear choices and astrophotography with telephoto lenses similar to author's.
Feb 1, 2025
