OSC RGB and Dual Narrowband Combination
4 replies440 views
Aris Pope avatar
I have a slight dilemma. I have collected about 3hrs of data on the Pac-Man Nebula using My 294MC Pro (OSC) with a UV-IR Cut (RGB) and 2.5hrs of data with my Antlia Dual Narrowband (Ha/Oiii) Filter. I'd like to combine the data in Pixinsight but not sure how.
So far I've processed the data separately to get two images. Then I added the stars from the RGB to the Narrowband using Bill Blanshand's RGB stars process. There must be a better way. Can someone help me??
Thanks
Aris
Jure Menart avatar
Hi @Aris Pope,
I am no expert (but did twice comine Ha to RGB in my pictures) and I am using mono, but I think good start would be to check NBRGBCombination script ( Script - Utilities - NBRGBCombination).
Another way is to use PixelMath for each channel (adding Ha to red and Oiii to blue/green). I think most people will say this is not the right approach but for me it was the easiest and I got most control, how much of Ha to add, example for Ha to red channel (I imagine Oiii woould be similar):
Where 1.2 is some factor I usually play around with and Ha is label of my Ha image (obviously)
patrice_so avatar
Hey there,
The above suggestion is surely a very good one.
Additionally, you might be very interested in this advanced guide for NB signal integration :
https://www.nightphotons.com/guides/advanced-narrowband-combination
Patrice
DavidT avatar
I'm sure there are better ways of doing this. But it works. I like using Bill's Add Ha to RGB formula.
In Pixinsight
1 use Image Integration on page one of Processes
2 Add Files. It wants 3 images so add the RGB twice and Dual Band once. Or visa versa.
3 Apply Global.
Hope this helps
Aris Pope avatar
Thanks everyone, that gives me some really good ideas to try!!
Can someone help me understand this processing workflow?
I have three nights of Eagle Nebula goodness captured in SHO+LRGB. I wanted to try out the workflow depicted here, using SHO for the nebula and LRGB for the stars. Now, I've done that combination before, but not using this workflow. If you look a...
SHO+LRGB workflow combines narrowband and RGB data like your Ha/Oiii+RGB setup.
Jun 24, 2025
Adding stars to starless image causes them to bloat - what am i doing wrong?
I have HOO & RGB data for the crescent nebula. I processed the HOO and the RGB seperately but ensured I had a staralignment done before processing. The images are the same size, I've tried to combine them both in 16bit and 32bit format and st...
Addresses star bloating when combining processed narrowband and RGB images together.
Jun 19, 2025
Pixinsight Help - Processing OSC data plus mono camera Luminance data
Hello, I recently acquired a mono 533mc camera. I captured luminance data on ngc 7331 with a uv-ir filter. I already owned a 533mc color camera and had some OSC data on the same target. I want to add the luminance data to my OSC dataset to improve th...
Directly covers combining OSC and filtered data in Pixinsight processing.
Sep 1, 2025
Dual-Narrowband filter+OSC vs. Ha/O3 filters+Mono Comparison
Hello everyone, Lately I have been thinking on which of the following - Dual-Narrowband filter+OSC and Ha/O3+Mono - is most time efficient for shooting and I'm starting to reach the conclusion that Dual-Narrowband filter+OSC may be a better optio...
Discusses combining OSC RGB data with dual narrowband filter data.
Jan 11, 2022
