FMA180 with focus issue
10 replies694 views
Werner Stumpferl avatar
Hi all,
I have some problems with focus with my FMA180. The focus is good for green and blue but red is complete out of focus. I have sent the FMA180 to my dealer and I got a new one for exchange. But the new one has the same issue and now the dealer says that this is normal with this scope because it is not a real color free APO.
Below you can see the result of a RGB-Image (with a OSC / QHY183C) where the channels are separated via APP.
Green - Blue - Red
Same happens with a dual narrowband filter like the l-Ultimate ... green/blue is sharp, red is totaly out of focus.
So my question is, is this really normal for this Lens ?
Alan Tidey avatar
I will follow this as I have the same scope. I use the ZWO ASI533MC camera with it so will check after splitting the channels. I've used it with and without the L-enhance filter.
AdamJ avatar
So I use a mono camera and although I shoot LRGB I have not noticed any significant shift in focus position when moving between filters.
I have the original FMA180, is yours a pro? It looks like it's a long way out not just a little bit out.
Adam
Adam
No, it´s the "normal" FMA180. As far as I know, the difference has nothing to do with the lenses, only with focuser and a integrated rotator.
And yes, both lenses are far away from focus in red.
D. Jung avatar
I have used a borrowed fma180 and used it with the Antlia dual narrow band. I did notice a slight focus shift between red and blue, but not even close to the level you see. It was more in the level, yeah, a bit shifted, but no biggy.
https://www.astrobin.com/1datgq/
https://www.astrobin.com/mahksn/B/
Below is the red and blue channel from above image. You can see the focus offset, but not as bad as with yours. I recall that this was ultimately the reason why i decided against buying this lens. You can fix it easily with BlurXterminator, but the lens is a bit too expensive for this level of chromatic aberrations in my book.
GregLatiak avatar
I got my FMA180 last summer and have only had a couple of sessions with it using my QHY183C. I did not notice any problems with focus at either end of the spectra.  My process for focusing any object is to use a focusing mask to get rough and finish using star image size. I do not have a power focuser on this scope. In my limited experience I would not consider this 'normal'.  I am assuming you focus through the filter – which appears to pass a number of deep red emissions, so being out that much in this area is curious.
AdamJ avatar
Werner Stumpferl:
Adam
*So they are optically different from the diagrams. Here is a link to my friends image with a UV/IR cut filter.
​​​https://www.astrobin.com/jt799b/
here is mine with SHO
https://www.astrobin.com/47y4ox/K/
Both sharp I am sure you will agree.
The issue comes when you stick a duel band on it and in that situation I know he has issues similar to yours.
​​​​​​I do think you are way way oversampling the scope with a 183mc pro, you got to remember that it's only for a 6um spot size and so the 294 is a better match.
@ChrisPeace  may well be able to shed more light on this. The shot the springs to mind is a wide field of the Cresent nebula /SADR area.
Personally I always thought it was an autofocus weighting green issue. But not sure you are using one.
Adam
Hi Adam,
yes, I´m using autofocus and he is weighting green/blue and independent if over- or undersampled (and I´m undersampled not oversampled), the same occurs with a 294c, red is out of focus. So my question was, has anyone the same issue or do I have simply two bad FMA´s ?
Werner
AdamJ avatar
Werner Stumpferl:
Hi Adam,
Werner
Ah yes the CCD suitability calculator, problem is it is wrong. It fails to consider two very important factors. 1) The Rayleigh / Daws Limits. 2) The actual resolving ability of the optics. In this case:
Daws = 2.9um Rayleigh = 3.45um and the Spot diagram for the scope is saying 6.8um. So the limiting factor in terms of resolving power is 6.8um.
You will never ever acheive 2.75 with the optic and so irrespective of anything CCD calculator is telling you in terms of sampling with its oversimplified model you are over sampled for the scope.
In my view its an expream effect and runs against my esperiance with the scope, which is that blue bloat happends not red bloat.
In my view its an interaction with the way the auto focuser is working and the optics and the bayer matrix that is resulting in a poorly optimied focus for a duel band filter.
In terms of, have i seen this before from the scope...yes I have but not on my own using a mono camera. @ChrisPeace  would need to comment.
Adam
Thank you to all … I got a new 180pro from my dealer. Your comments and experiances have helped.
Here is the result, 2 hours with QHY183C and Optolong l-Ultimate at a FMA180Pro, O3 and Ha seperatet with APP. All is perfect now.
Ha
O3
Astronomik Filter Halo Story
This will be long, TLDR: Myself and at least a few other competent imagers have had recent issues with Astronomik Deep Sky RGB filters and Astronomik's customer service. Buyer beware. I will preface this by stating that I am not looking to bash a...
RGB filter issues with color separation and focus problems directly relevant.
Feb 8, 2025
Review: ToupTek 36mm LRGB and SHO Filters.
Thought I'd share my thoughts about the ToupTek Astro filters I've been using. Brilliant budget friendly filters. ToupTek Astro 36mm LRGB + SHO Filter Review. Introduction.We all know how expensive astronomy can be. Further to that, we all kn...
Alternative filter options for RGB imaging and color channel performance.
Mar 27, 2025
Issues with Star Alignment using Chroma Filters
We use 14 Chroma filters for my astrophotography; 7 are 36mm LRGBSHO, 7 are 50mm LRGBSHO. The narrowband filters are 5nm (SII and OIII) and 3nm (Ha). In this post, we present two issues occurring with two different telescopes, both of which have the ...
Relevant; chromatic focus issues across wavelengths similar to filter separation problems.
Dec 20, 2021
