Georg N. Nyman avatar
Hi everyone,
maybe one of you can help me - I am using my CEM120EC2 with NINA (current version 2,3RC1). In NINA, I add the iOptron commander (ver9) as telescope - and then it happens - most data are strange and/or wrong - see attached screenshot. The guiding works fine, but the flip time is logically wrong and every other figure from the commander as well, except the altitude, which is correct.
But if I add "device hub" as telescope - with the CEM120EC2 as mount selected - all data are correct. But then - no flip organized by NINA - the flip happens but managed by the commander software. This means, I need to watch the time, stop acquisitons and have to recenter manually after the flip.
Have you ever experienced this! What do you suggest me to change/do?
Thanks and regards
Georg
GalacticRAVE avatar
I have the same mount, never had that problem. But one thought: do you have your PC set to German number format, i.e. 27,7 arc sec vs 27.7 arc sec.  there is a considerable number of software around who have poor implementations (including - surprisingly - pretty much all banking softwares). if there is an translation error, 47,00 degrees would become 47000 degrees … and your screenshot reminds me of that. Maybe worth to check and reset this in the windows config and give it a shot. Matthias
Helpful Insightful
I have the same mount, never had that problem. But one thought: do you have your PC set to German number format, i.e. 27,7 arc sec vs 27.7 arc sec.  there is a considerable number of software around who have poor implementations (including - surprisingly - pretty much all banking softwares). if there is an translation error, 47,00 degrees would become 47000 degrees ... and your screenshot reminds me of that. Maybe worth to check and reset this in the windows config and give it a shot. Matthias
Oh, never thought about this....yes this makes sense! I shall check it asap!!
Thanks
Georg
Georg N. Nyman:
Thanks
Georg
I just changed in NINA the language from German to English(US) and everything is correct now! Thanks thousand times for this hint - you nailed it perfectly - that was the problem - German annotation of commas vs US with dots...!
Georg
Keller F. avatar
German to Englisch ist die Lösung!
CS Florin
DISCONNECTION WITH IOPTRON COMMANDER
HELLO EVERYONE I have an ioptron cem 120 EC2. Randomly the ioptron commander application disconnects saying that it can't find any devices anymore. Looking in the USB peripherals I see the mount connected. The only way to reconnect the applicatio...
Addresses iOptron CEM120EC2 disconnection issues with commander software.
May 22, 2025
Remote Imaging When The Roof Closes
I'm trying to understand the best sequence of operations when the roof closes. I am using NINA with the Powerups plugin. NINA gets data about the roof condition via ASCOM drivers. I use "When Becomes Unsafe" and "When Safe", w...
Discusses NINA software configuration and sequencing with equipment control.
Jun 11, 2025
