Plate solving fails on uploaded images
Support requests are handled via the support form so they can be tracked and resolved properly. This section is for community discussions about the AstroBin platform.
Jan Erik Vallestad avatar
I've experienced issues with plate solving today on new images, this one which is made public doesn't seem to be solved at all:
https://www.astrobin.com/xm03eh/0/
However when I do it on Astrometry.net it seems to work just fine:
https://nova.astrometry.net/user_images/8459467#annotated
Has anyone had similar experiences lately?
Edit: Turns out it solved itself now after several automatic attempts, I must have seen it fail between 5-10 times before I wrote this post though.
Salvatore Iovene avatar
The image you linked appears to be solved. What am I missing?
Salvatore Iovene:
Indeed it is, I probably should have been a bit more patient that's all. It just took an unusual amount of time/attempts. The image in my staging area took about three or four attempts, this one needed a lot more.
Scott Stirling avatar
I came here to report the same observation with a couple images yesterday and again today.  The same solve fine locally in Pixinsight.
James R Potts avatar
My image that I just loaded will also not plate solve.
Working.  Both images plate solved now.  Thanks!
I am not sure whether the issue is just a queue exceeding a limit at the plate solving endpoint, or what, but if so it cleared.
Still happening on my end, but I'll just let it run. You're probably right in your assessment of the issue.
Ruediger avatar
Same for me when browsing through the images. Approx 50% to 60% show following:
Rick Schneider avatar
Under the Edit dropdown, there are two options - Plate Solving Settings and Advanced Plate Solving Settings. You can adjust settings there that give the plate solver a better chance. Particularly useful (for images that are very difficult to plate solve) is the option under Advanced Plate Solving to upload an unstretched raw frame of the image. For mono, use the calibrated, unstretched luminance image if you have it. Note that it needs to be aligned with the image you are trying to solve to work properly.
Hope this helps.
Well Written Helpful Concise
