Filters for 16200
3 replies174 views
akulapanam avatar
I currently have Optolong LRGB filters that I'm using with my 16200 based camera.  I'm finding that my blue frames need 2 minutes of extra exposure to get close to the same ADU of my R and G frames (if R&G are 1200 then blue might only be 200-300 for the same exposure time).  Thinking about buying Chroma, Astronomik, or Astrodon type E filters as replacements.  Was curious if some individuals could post what they get for background values for their RGB frames with Chroma and Astronomik Deep Sky in particular.
Well written Engaging
Ruediger avatar
Hi, I also owned a KAF16200 based CCD and had observed the same behaviour, but this was not related to the filters. If you check the tec specs for the sensor you will see, the quantum efficiency is at lowest for blue frequencies. That is the main reason. This is based on the effect that photons can not penetrated deep enough into the CCD semiconductor.
This effect is valid for almost all CCD.
Reference: https://www.onsemi.com/pub/Collateral/KAF-16200-D.PDF
akulapanam avatar
Yeah I get that but the difference is too large to be explained by the sensor alone.  I have had a couple people provide Astrodon examples now and they are within 10% of each other.
Morian avatar
But also keep in mind that transparency is not necessarily the same from one day to the next, if you do not take them the same evening
I also checked my RGB in SGP around a project I also have Optolong filters.
Removing the fixed-pattern background from GSENSE4040-based camera images
INTRODUCTION This post presents a calibration strategy that removes virtually all of the fixed-pattern background in most deep-sky images taken with GSENSE4040-based cameras. This chip has a so-called scientific CMOS (sCMOS) architecture, which provi...
Fixed-pattern background removal relevant to camera sensor calibration issues.
Mar 20, 2022
RGB filters
I'm going to be getting an ASI1600MM soon and can't decide what to do about rgb filters. I currently have a set of Astronomik LRGB type 2c 1.25" or I could get one of the ASI1600 combos with the ZWO rgb filters and sell my astronomik one...
Addresses LRGB filter performance issues with similar 16200-series camera model.
Oct 13, 2018
Baader CMOS optimized filter for TV-NP127is and QHY600
I am the owner Tele Vue NP127is telescope QHYCCD QHY600M with QHY accessories: QHYCFW3L and QHY OAG-M. My scope is bright for APO F/5.2 and in future I will buy the TeleVue 0.8 reducer (currently I am using LCL-1069) then the focal ration change to F...
Filter selection and optimization for CMOS cameras with RGB imaging.
Jul 7, 2021
