Antlia 3nM compared with Baader 4nM narrowband filters. Comments on either.
17 replies814 views
David Moore avatar
I currently useing Baader 6.5-8.5nM narrowband filters and I am thinking about going for something narrower but not too expensive. I would be interested on users experience of Antlia 3nM and Baader 4nM filters, particularly in Ha and OIII but also SII.
My scope is an 8", F5, 1000mm f.l. Newtonian so I am not interested in the fast scope filter versions.
Bray Falls avatar
I use a set of 3nm antlias on my FSQ85, and they have performed well for me.
JohnHen avatar
Hi David,
I have both the UNB Baader CMOS and the Antlia Pro 3nm (on different refractor scopes both ~f/5-6). Had the Baader first and then got the Antlia to see if they are any different. And indeed, there is a difference: When I started imaging with the Antlia, I was surprised to see how little signal was visible a single sub (on a quite faint Ha source) as opposed to the Baader. But when I had collected/stacked many hours, it was apparent that the Antlia provided a higher contrast i.e more details (at the cost of larger integration time). This is my experience that is by no way a quantitative analysis and it is neither exhaustive etc. Both are good  value for the money and you won't regret buying either. But if you look for extra detail (in some!) targets and are wiling to put extra integration time, then the Antlia may provide some more detail.
Hope that helps. CS, John
Helpful Insightful Respectful Supportive
Rob Lyons avatar
I have 2 sets of the Antlia 3nm and think they are fantastic. The OIII is a huge step up from wider bandpass filters and the improved contrast overall by going narrower is well worth it. I upgraded from 7nm filters and the difference was rather dramatic. I have even shot 0III around the full moon and gotten amazing results.
Chris McGrew avatar
I love the Antlia 3nm. Great value for money, work great, very good halo control. I like them so much I have 2 full sets of LRGBHSO for my twin rigs, and shoot away no matter the moon phase. Most of the work on my page was done with Antlia filters.
Minh Lết avatar
Antlia all the way. Baader's NB filters are trash. Extreme halo on bright stars.
TakFan avatar
UNB Baader Ha gave me halo while Antlia Ha works fine. All other Baader filters were absolutely OK. Baader refused Ha filter exchange and claimed halos are caused by the optics and not by their filter.
Optics TSA-120 with Tak reducer.
Dirk
David Moore avatar
Thanks everyone for your experiences. I often get haloes with my approx 7nM Baader SHO filters, different ones depending on which target I am imaging. I shall be getting Antlia, one at a time due to the cost.
Josh Jones avatar
I also had baader for a while, but moved to astronomik maxfr and so much better.  They work really well on fast optics as well.
Donna Harris avatar
David Moore:
I’m using the Antlia 4.5nm filters. This is my first monochrome camera experience but I am very happy with the results.  I went with the 4.5 because they were less expensive than the 3nm but also because they require a little less exposure time.  I’m  using these with the ASI533MM with 1.25” filters (also a cost savings).
Well Written Concise
Robert Khoury avatar
I get halos with my Antlia 3nm Oiii and smaller halos on my Sii. Ha works wonderfully. I'm not sure if it's quality control issue but they're there. I haven't tried shooting in full or anything higher than 50% moon yet. I do aim for 15 or more hours in total integration time and so far from my 4 images having made the switch to mono this year very happy with the results. Unfortunately no direct comparison to other filters vs my experience using a 12nm dual-band in OSC
Minh Lết avatar
Robert Khoury:
try flipping your filter. If that still does not work then the halp may comes from your optics or camera rather than the filter.
Minh Lết:
Robert Khoury:
These are the threaded 2" ones so I would assume not on backwards. What issues with the scope or camera could be causing it? The camera is brand new
Minh Lết avatar
Robert Khoury:
Minh Lết:
Robert Khoury:
some camera have low quality chamber windows AR coating that could cause halo. Also the reducer/flattener without proper AR coating also may cause halo.  My QHY294M had a slight halo with the antlia 3nm O3. But it's gone after switching to the 2600MM.
also the O3 is expected to have some halo around it. Even my Astrodons shows some halo around the Alnitak on O3.
Minh Lết:
Robert Khoury:
Minh Lết:
Robert Khoury:
*Interesting, thank you. Yeah I'm using the 2600mm as well with an Askar 500 so no FF or reducer. So far the halos have been easy to correct using clone stamp after star removal. I'll keep an eye on it though
Minh Lết avatar
Robert Khoury:
Minh Lết:
Robert Khoury:
Minh Lết:
Robert Khoury:
The FRA500 has a 2 elements ff intergrated
Minh Lết avatar
The halo, if caused by the ff tends to be really big.
Minh Lết:
*ok I think optics should be ok. The one halo I had to deal with so far with my new mono setup was the bright star near the Tulip nebula. If I remember correctly diameter of 100 on clone stamp removed the halo after star removal quite nicely. So probably not too bad of an issue? I only had halo issues with two other images; horsehead and Ghost of Cassiopeia. Those were much larger rings (and expected to see them) but I was using a 12nm dual-band with a 2600mc.
Choosing SHO filters for RASA 8
I bought RASA 8 recently and I'm still thinking what is the best choice for monochrome narrowband filter to me - if the budget is limited as mine excluding Astrodon and Chroma options. So I think that my options are Baader F2-ultra-highspeed (3.5...
Discusses narrowband filter choices for monochrome imaging with budget constraints.
Mar 13, 2025
Looking for Advice on SII & OIII Filters - Halo Issues with Askar D2
Hi everyone! I need some advice on narrowband filters. I currently own the Askar D1 and D2 filters. The D1 is fantastic great colors and truly halo-free. However, while the D2 produces nice images, I’ve been struggling with halos, which is quite frus...
Addresses narrowband filter selection and halo issues with specific filter brands.
Jan 29, 2025
Dual Band Filter Discussion
I am looking at getting into nebula imaging more and want to get a good Dual Band filter. I am using 2 different OSC cameras the asi533mc and as asi2600mc duo. I am basically in a bortle 7 I have a ZWO dual band filter but it gets halos on all my sco...
Covers dual band filters for nebula imaging; relevant to narrowband filter discussion.
Apr 16, 2025
