How to tell if there is Sii in a region?
Salvatore IoveneTareq AbdullaArun HJeffrey Horne
32 replies1.8k views
Jeffrey Horne avatar
Hi friends,
When planning targets, I find it fairly easy to know which areas have Ha and Oiii, just from looking at other images and various surveys on Telescopius (DSS Red, etc.)
I'm having a hard time finding if a target has any Sii, and if it's worth spending hours and hours on Sii when the target might be better off as HOO.
I know it's fairly easy to tell by looking around on Astrobin and seeing if people have piled on Sii data for a particular target, but I'm working on a region that doesn't have a lot of images, and it's hard for me to tell if there is Sii in the region.
Thanks in advance for your help, and clear skies!
Jeff
Salvatore Iovene avatar
This gives me an idea to add a search filter to find images that have been acquired with a certain type of filter 😃
EDIT: this is done now, please see some messages down this topic!
Salvatore Iovene:
I love this idea, @Salvatore!
Steve Spring avatar
Great question Jeffrey,
I shoot OSC with Ha/Oiii dual band so no experience with SI at all.
Would love to give it a try especially as there are now a couple of Oiii/Si dual band filters appeared on the market.
Steve
Lynn K avatar
Because indivigual post processing can vary, it may be difficult to determine the amount of SII in an object from a photograph.  I just bin the camera 4x4 and do a 3 to 5 min test image.  Or may have to take 3 to 5 images and do a quick stack. This may take a little time, but less than culling through Astrobin.   Or wasting hours on non productive data.
Lynn K.
Concise
Tareq Abdulla avatar
The problem is if doing a large wide FOV or even Mosaic which you can get some areas with SII and other areas weak to no SII signal, so you don't know if you should include SII or not, for example the Veil, it is Ha/OIII perfectly, i didn't see much of SII there even if it is included, while NA/Pelican are rich with SII, Crescent isn't much of SII region while Tulip is, so if i image Cygnus region, parts are perfectly Ha/OIII alone and parts need to be SHO.
Lynn K avatar
My comment was in regard to using a mono CCD/CMOS camera with individual Ha, OIII & SII filters, not OSC dual band.
Lynn K.
Christian Bennich avatar
Jeffrey Horne:
Salvatore Iovene:
+1 for this idea as well 👍👍
Mickaelle (kaelig) avatar
I have discovered recently thank to an astromical friend, the excellent work of Gary Imm (which is here on our forum). It is an amazing job with a lot of informations & with an information about the filter to be used.
http://garyimm.com/compendium
Eddie Bagwell avatar
Salvatore Iovene:
Great idea and please make it available to all subscription levels. Thanks!
Frank Alvaro avatar
Salvatore Iovene:
Coincidently, without having previously read this thread, I was using the search function yesterday to see if "filter type" was an option...so I would happily see this feature implemented
+10 for that filters search idea
Stuart Taylor avatar
Salvatore Iovene:
Yes please Salvatore!
Jonny Bravo avatar
Tareq Abdulla:
No S2 signal in the Veil? My data begs to differ with that assertion...
Data acquired with my 294MM Pro, GT81 and a Chroma 3nm S2 filter.
If it weren't for people trying certain not-often-used filters in certain portions of the sky, we would never have discovered that lovely O3 around M31: https://www.astrobin.com/1d8ivk/#
So, I say try it. Who knows, maybe you'll find some previously unknown S2 region somewhere
Helpful Insightful Concise Engaging Supportive
Gary Seven avatar
If it is not a Planetary Nebula, I assume it is there and run a few 5 minute test exposures.
Often it turns up - the only question is if the amount is worth devoting time to.
Jonny Bravo:
Tareq Abdulla:
I mentioned this region and also Crescent because i saw people captured those in SHO and HOO and i hardly to see difference, it is like there is no SII, or very slightly there that can be neglected, unless people don't know how to process it to show it clearly.
Salvatore Iovene:
@SalvatoreI've been thinking about this...I assume you mean that you could search for images taken with any Sii filter, not just a particular brand, right? That makes a lot of sense as a future feature!
Jeffrey Horne:
@Salvatore I've been thinking about this...I assume you mean that you could search for images taken with any Sii filter, not just a particular brand, right? That makes a lot of sense as a future feature!
That's right. This is most likely going to be released tomorrow. You will be able to search images acquired with a certain filter type (or combination or filter types).
E.g. want SHO images? Search for Ha + SII + OIII filter types.
Have fun everybody! 🎉
Michael W. Dean avatar
Salvatore Iovene:
Yes please!
@Michael W. Dean see the message just before yours, it was just released!
Arun H avatar
Salvatore Iovene:
Seems like it needs an Astrobin Ultimate subscription
Arun H:
Hi Arun, yes, sorry that I couldn't make it available to all subscription tiers. All other more specific filters are under Ultimate too, and of course I need to have as many people as possible on Ultimate in order to continue and provide an excellent platform for all of you.
As I've mentioned somewhere in the past, personally I'd be the happiest if I could get rid of these tiers, and make a single plan, cheaper than Ultimate is currently.
But this is a risky move that I don't feel comfortable doing at the moment, until I do extensive polling of current and potential customers to understand if it's a viable option that won't reduce revenue.
The good news is that you can upgrade and get a refund for the unused portion of your Premium.
AstroBin Ultimate is $5.75 USD per month, when paid yearly, if I recall correctly, so I don't think that's unfair to ask for a platform that is continually improved.
Thanks for considering!
Well Written Helpful Respectful Supportive
Arun H avatar
Salvatore Iovene:
Hi Sal, I don't think it is unfair at all! Actually, I had not realized the savings if paid yearly. I suspect if you add a blurb saying "savings of $20 if paid yearly", more people might choose Ultimate.
Arun H:
Thanks for being so understanding! Actually, the default payment period is yearly (you have yearly but non-auto-renewing).
When you click the Monthly toggle, you can see the price change and when you are on the actual payment page, AstroBin does already tell you "Save ~20% by switching to a yearly payment" so it's already set up
Incredible Narrowband Survey for Finding New Targets
Hey everyone, I just wanted to share a great resource I just recently found for finding new narrowband targets - the Northern Sky Narrowband Survey by Stefan Ziegenbalg. It seems to be a high-resolution, very detailed, and very deep narrowband survey...
Narrowband survey resource for identifying SII and other emission line targets.
Apr 19, 2025
Review: ToupTek 36mm LRGB and SHO Filters.
Thought I'd share my thoughts about the ToupTek Astro filters I've been using. Brilliant budget friendly filters. ToupTek Astro 36mm LRGB + SHO Filter Review. Introduction.We all know how expensive astronomy can be. Further to that, we all kn...
Filter review relevant to SII filter selection and narrowband imaging planning.
Mar 27, 2025
