APP Correct Vignetting gives Black/White Screen—what next?
3 replies85 views
schmaks avatar
What am I missing? In tutorials it applies the correction; it's not the case when I do it.
Thanks for the advice.
Jesco avatar
The vignetting tool never worked for me. It is also only supposed to be used when you did not use any flats for image calibration.
I would try to correct any gradients in your image with the remove light pollution tool. This works very well, usually.
schmaks avatar
The vignetting tool never worked for me. It is also only supposed to be used when you did not use any flats for image calibration.I would try to correct any gradients in your image with the remove light pollution tool. This works very well, usually.
Good to know I’m not the only one.
That’s what I have been doing.
astropical avatar
The vignetting tool was a gamble for me, too, sometimes good, sometimes white. Frankly, I didn't know what I was doing, so, not blaming APP. I changed to Fitswork for removing vignetting an uneven background. So far working great.
Milky Way Pano Stacking and Stitching Worflow - Issue with Lens Profile Correction w/ TIFFs post-Stacking
Hi People, I am looking for some suggestions on how to stack and merge a Milky Way Panorama shots. I know the process and have watched quite a few tutorials on Youtube. This might sound like a naive question but I just want to try my luck here. The w...
Author struggles with tutorial corrections; candidate discusses workflow issues with lens profile correction.
May 11, 2022
