mousta avatar
I have used my Celestron C6-N with an Advanced VX mount and T3i DSLR to take my first few shots. I think they turned out decent, however I always feel that the focus isn't right. I read multiple articles about focus problems with Newtonian telescopes and DSLRs. I screw the T-Ring directly to the 2 inch part of the focuser, this gives me the best focus in the telescope. I can't tell if its good enough or not because I haven't seen another reference to compare. A friend has an Orion ED80T that is offered to me. Should I just give up imaging on the Newtonian and use the Orion scope ? My main problem is that I don't know if the problem is in my skill  (alignment, software, etc..( or the equipment at this time and if things just work magically using the Orion I feel I will never know.
Any thoughts ?
mousta avatar
Trying to bump this up - any one has thoughts ?
Roy Hagen avatar
Hi Moustafa
Did you purchase a Bathinov mask?
Very useful to achieve perfect focus.
https://www.youtube.com/watch?v=013CTFptjMQ
Fast newtonians also need a coma corrector
https://www.youtube.com/watch?v=tSKN6Bsed0c
Concise
Michel Makhlouta avatar
Hi Moustafa,
I've started this hobby with a C8-N, so I will share my experience. For newtonians, you will need a coma corrector. As you've done, the only way to reach focus with the celestron newt is by screwing directly that part of the focuser into the t-ring. If you want to use a coma corrector, that will screw in the tring and you won't be able to reach focus anymore. The solution for that, is to cut a piece of the tube (3.5cm in my case) and bring the primary mirror closer to the secondary. You may also want to consider upgrading the focuser, a low profile focuser might save you from modifying the primary position.
Newts also require to be collimated, this is something you need to put some time on to learn and perfect, from centering the secondary in the tube and in the focuser, all the way to aligning the primary mirror with the secondary. A Bahtinov mask is a must for reaching proper focus. One you've focused, try to refocus every hour or so, to check if the focus is shifting.
Looking back at my experience, I am glad I went through this, as a learning experience. But I would have gone with an 80mm refractor if I had to start all over. I am not saying the newt was useless, I've had some decent images with it, but it's up to you to weigh the pros and cons. Celestron newts weren't designed for astrophotography as a primary concern.
mousta avatar
Roy Hagen:
Hi MoustafaDid you purchase a Bathinov mask?
Thanks Roy - This is an interesting inexpensive idea, I will try it
mousta avatar
Michel Makhlouta:
Hi Moustafa,I've started this hobby with a C8-N, so I will share my experience. For newtonians, you will need a coma corrector. As you've done, the only way to reach focus with the celestron newt is by screwing directly that part of the focuser into the t-ring. If you want to use a coma corrector, that will screw in the tring and you won't be able to reach focus anymore. The solution for that, is to cut a piece of the tube (3.5cm in my case) and bring the primary mirror closer to the secondary. You may also want to consider upgrading the focuser, a low profile focuser might save you from modifying the primary position.
Hi Michel,
Thank you for the through explanation. Really helpful. Honestly, I like newts because of the star diffractions . I realize now that its going to be painful to get this right. I will probably buy the Orion Astograph 6' or 8', comma corrector and bahinov mask. I have no problems with the collimation, I have done it multiple times using a laser collimator.
I will keep my C6-N for visual. BTW, I tried the 80mm refractor and OMG - Everything was like 10x easier got good photos of M51 with it, will share it next week once I'm done shooting since we have got a lot of clouds here.
Thanks again
Problem with M54 extender and coma corrector.
I have a TSFMA360 focuser that I want to use with a TS 1.0x coma corrector for Newtonian telescopes, so that the corrector can be screwed into the focuser. I have an adapter to be able to screw it in.The problem is that, because the drawtube of the f...
Both posts describe technical challenges with achieving proper focus when using accessories with Newtonian telescope focusers.
Sep 16, 2024
Custom Newtonian Builders in the US?
Hi, I'd like to build a 10" F3 newtonian with a curved spider, and a Big Paracorr coma corrector for full-frame astrophotography. I want a carbon fiber tube and everything screwed into the focuser (including coma corrector) then OAG then Fil...
Both posts describe challenges with achieving proper focus and optical alignment when using Newtonian telescopes with DSLR cameras for astrophotography.
May 8, 2024
ChatGPT and oval stars
An interesting exchange with ChatGPT regarding a new onset problem with stars across my entire field of view being oval shaped, and all elongated in the same direction. Exchanges are summarized due to the wordy nature of ChatGPT. What is interesting ...
Both posts describe challenges with achieving proper focus and image quality when using telescopes with cameras for astrophotography.
Feb 13, 2026
