Non-Guided Exposure Time / Adjustments
7 replies252 views
schmaks avatar
How long of an exposure is safe when shooting unguided? I’m using an HEQ5.
Also, how do you go about manual adjustments if you’re visibly drifting to keep your subject in frame?
(I know, I need a guide scope/system—but until I have one…smile
wsg avatar
With good balance and polar alignment my CEM 60 has surprisingly round stars  with 2 to 3 minute exposures unguided. I've never used one but yours is a comparable mount to mine.  30 to 60 seconds should be easily attainable with your HEQ5.  Most of my images on Astrobin are unguided at 30 or 60 seconds, often with 90 or 120 second shots mixed in on the fly.
Scott
Stefano Ciapetti avatar
That's really depend on the mount. With my Vixen GPDX I have done unguided exposures of 3 minutes even at 1600 FL. With my CE60 I do maximum 1 minute. But it also depend on the kind of camera you are using. With CMOS cameras short exposures are very good (and then stacking them). I am doing only unguided exposures. However it's good if you are using a PC and the aquising software can do a plate solve and automatically, if the object is moving too much from the center, it can center the object again and keep exposing.
There are several software that can do that. I have made a very simple script in Astroart which works very well.
Stefano
schmaks avatar
So would the manual process to be stop shooting, resented with the hand controller then begin again?
wsg avatar
When I shoot with my DSLR I stop the camera and carefully change what ever setting i need to, usually exposure, leaving the mount tracking. You can't really hurt the mount if you take care, but I have found the more I can leave the mount alone, the better my images are.  Just be sure to eliminate any frames with motion blur before you process.
schmaks avatar
I am more so curious about manually adjusting the mount of the subject drifts off-center; not adjusting the camera.
Suggestions?
When I didn't have the software doing it I did it manually. I knew approximately how long the object could stay in the center (or nearby)  of my camera (a DSLR) and after a certain number of exposures, I manually recentered the image using DSLR screen and doing a short exposre to check. A real pain.
Via software it's easy. I go to bed and leave the mount and the computer doing all the job.
Concise
Scotty Bishop avatar
I've done up to 2 on my CEM25P, but it really depends on your focal length, weight, polar alignment, and how windy it is.
Telescope security system
Hi folks, I am working on a small device aimed at keeping your telescope safe when you leave it shooting unattended. The device will be battery + USB powered, easily attachable to any part of your rig and will be able to detect movement around it, vi...
Battery-powered security device irrelevant to exposure time or manual tracking adjustments.
Oct 19, 2021
New to narrowband (SHO). Suggested exposure times? Calibration frames, etc?
Hi! Stepping into narrowband with a 183GT, shooting SHO and need some tips. My setup is a ZS73 scope on a HEQ-5 Pro Mount with ZWO guide system, etc. How long should my exposures be? How many calibration frames (darks, flats, bias) should I need and ...
Same mount model (HEQ-5) with guide system discussion relevant to author's setup.
Apr 8, 2022
Dithering ? No guiding system ? No problem !
Note: if you are a lazy person this is not for you! Hello folks, I have been doing astrophotography for 3 years now, my current setup is (modified DSLR, star tracker, and L-enhance filter), Bortle 8-9. I started with a normal tripod and a camera then...
Addresses unguided shooting and manual adjustments without guide system—directly relevant.
Jan 24, 2022
