UV/IR Cut filters with RC telescopes
6 replies195 views
Matthew Proulx avatar
I was reading somewhere that a UV/IR filter is not required for a pure reflector system, could someone shed some light on this for me? Thankyou.
Well written Engaging
Tolga avatar
Refractors are designed to focus the visible rgb light. CCD/CMOS sensors detect into UV and IR. See your camera's QE curve. UV and IR light in refractive telescope will be slightly out of focus if you don't filter them out. In a purely reflective system you don't get this prism effect refractors have. So you can use a clear filters instead of an L filter. However I am not sure if you can have a truly pure reflective system. There is usually glass somewhere.
Tolga:
My Ritchey-Chretien is 2 hyperbolic mirrors and a camera sensor. By definition of truly pure reflective system, that is it.
Dale A Chamberlain avatar
Wouldn't an RC with a focal reducer/flattener change that?
Christopher Gomez avatar
Dale A Chamberlain:
yes because at this point you would have introduced glass into the imaging train
Dale A Chamberlain:
Sure, but I'm not using one.
Marc Agostini avatar
In that case, the only glass I can think of would be the sensor protective window, which in case of your ASI 294 is an AR-coated thin parallel piece of glass and thus it should not cause any major abberations.
You should definitely give it a try! Especially in some dusty regions like the cygnus wall area, loads of stars and some little nebulosities unseen in visible light start to pop out in IR. I tried it once with my APO but of course the stars were fluffy as hell ;)  But on a purely reflective system like yours they should be nice and crisp anyway!
Another consideration is what color the additional IR light will have on a OSC camera like your ASI 294. Since the spectral response of the IMX294-chip looks something like this:
 (From MallinCam SkyRaider DS10C TEC, same sensor as ASI294) I would guess everything might get a bit reddish.
One more thing: main mirror reflectivity tends to twindle out over 700 nm, which might act like an IR-filter in itself.
So I guess the bottom line is like always: you have to try to find out. But isn't that the fun part of the hobby ;)
What IR-Pass Filter Do You Use, 685nm or 742nm?
Hello all you lunar imaging GURU’s! I have seen some of the incredible lunar images here on AB and obviously with excellent processing techniques there seems to be on thing in common. IR Pass filters to be specific. In doing some reading on what filt...
Discusses IR-pass filters relevant to reflector telescope optical systems.
Jul 1, 2021
Narrowband filters for fast optics
RASA telescopes, Hyperstar systems and other fast optics is growing quickly in popularity among astro photographers. However popular, these systems requires costly, special narrowband filters with shifted band-pass, and finding good such filters is n...
Addresses filter selection for optical systems, potentially covering reflector considerations.
Jun 18, 2021
