Mossyback avatar
A couple of weeks ago I posted about what setups you've found most reliable. I've replaced trying to go from a Mac in the house to a PC in the observatory. I purchased two Quieter 3Qs, one in the house and one in the observatory. Connection with the Observatory is quick and smooth and I've got everything running well in  N.I.N.A.
Two Questions:
1. My mount is an SB MtY. I start TSX first and select a target before switching over to N.I.N.A.. TSX wants me to home the telescope so that it knows where it is. In N.I.N.A. there's a button to do the same. Which one should I be using and are they the same?
2. Parking the scope is also a problem. TSX has a park position but in N.I.N.A. the scope doesn't respond to the park command. Should I be setting up the park position in ASCOM? TSX?
Aside from these two problems things are looking up. (No pun intended). Thanks again to those of you who pointed me down this path.
Hank
Helpful Respectful Engaging
Sean van Drogen avatar
Are you using the advanced sequencer? Both these commands are available in the advanced sequencer
Is It Me or the Camera?
After a fantastic first night out with my new ZWO ASI533mm, things took a turn for the worse tonight. (MtY Mount, 120mm Esprit, N.I.N.A. and the above camera on Windows 11) I was able to do an autofocus run on NGC 5457 using Hocus Focus with no probl...
Author uses N.I.N.A., MtY mount, similar equipment setup and workflow.
May 27, 2025
Parking problems to custom position with EQmod (in NINA)
Hi, I have been having issues in NINA with sending the mount to a custom parking position in EQMOD. Let me explain: I have set in EQMOD a custom parking position (mount in orizontal pisition with CW bar orizontal and scope pointing approx 1 degree ab...
Author uses N.I.N.A. with mount control; parking/positioning issues relevant to setup.
Nov 19, 2024
Finally downloaded NINA
I just downloaded NINA yesterday. Finally made the jump from Nebulosity for image aquisition. Got everything connected and working. Just need some clear skies to test plate solve and autofocus. I'm pretty excited about being able to setup and sta...
Relevant - discusses NINA setup reliability, matching author's recent transition and interests.
Nov 23, 2021
New Mini PC user
Hi guys! I need some tips for the mini pc. I switched from ASI AIR to the mele quieter 4c mini pc. I set up a persistent hotspot and nina and everything. However i found the the whole setup to be quite unreliable! For one, the Hotspot is very weak an...
Author switched to mini PC setup; directly relevant to Quieter 3Q transition experience.
Nov 29, 2024
