Just bought a new S.W. CQ350 mount and the Dec backlash is 0.5mm at the end of the saddle! Does anyone know how to adjust the Dec backlash on these mounts. Thanks
The first version of this mount do not have these 4 screwes and the backlash can not be adjusted from outside. You need to open the whole mont and do the same thing like in the PDF. Marc
Hi Bronco, I was able to get a reasonable result by using the attached PDF. This document covers both the early version and the later one. However the manufacturing tolerances prohibited a perfect result.
Hello all! I will soon be installing a CQ350 mount on my observatory pier, but I couldn't find a reliable source of information or technical drawing of the base of the mount head, where I would fit my personalized adapter for my pier. It looks li...
CQ350 mount technical information and setup guidance directly relevant.
My pier adapter plate hasn't come yet so i'm left alone in the basement with my thoughts. Anyone else decided to flip the saddle 180 so that the power/data hub connections are in the rear instead of front? Would seem to make more sense for bo...
Saddle orientation discussion may relate to mount adjustment procedures.
