WO GT 71 II + Flat6A III + Nikon D5600 Spacing question
3 replies109 views
Lukas Šalkauskas avatar
Hello there,
I have a problem of finding out correct spacing on Flat6A III for my Nikon D5600.
firstlightopticsoptics suggests 7.1mm:
https://www.firstlightoptics.com/reducersflatteners/william-optics-adjustable-flat6a-iii-08x-reducer-flattener.html
williamoptics suggests 9.1mm:
https://williamoptics.com/2019-all-new-adjustable-flat6aiii-t-mount-not-included
Which one is correct and is there any ways to check if its correct 100%(I can get focus with bahtinov mask by using  telescope focuser, should I see something strange by using bahtinov mask if the spacing is not correct)?
matthew.maclean avatar
I had already replied to your previous thread earlier today also. I assume WO has the correct spacing since they designed it, but I would suggest you email them directly ( wo -AT- williamoptics.com ) and get them to verify the correct spacing? They do seem to answer quickly the couple times I have emailed them.
Then post their answer here so we all have the benefit of the right value? I think my images look reasonable in the corners in general, but I’d like to know if I’m 2mm off too!
Just got an reply from WO:
DEar Lukas.Flattaner settings should be - 9.1mm
Regards,
Tim
WO
Matthew you were correct
I wonder is there any software I could use and verify the spacing is correct by giving my sample image?
I do not know of any software, but I think that you could probably use the Bahtinov mask to at least check the flatness next time you set it up - if you put a bright star in the center of the field, line up the diffraction spikes, and then rotate that star to each of the four corners, the spikes should stay lined up if the field is completely in focus. I bet it will be close.
Help with Coma Corrector Backspacing
Hello, I recently finally purchased a coma corrector for my 6" f/5 Newtonian and I am having some serious difficulty getting the backspacing correct. Everywhere seems to say 55mm is the most common, but I have seen in a couple places that 75mm m...
Jul 9, 2024
Both posts describe difficulty determining the correct optical spacing or backspacing distance needed for accessories attached to their telescope and camera systems.
FLAT with a strange pattern, I can't properly correct the LIGHTS / SkyWatcher APO ESPRIT 120 / x0.77 Reducer SkayWatcher / QHYY 268 mono / Chroma 3nm SII 36mm and OIII
Hello, I have a problem I can't seem to solve. If anyone can shed some light on it, I'd appreciate it. I'm testing a new setup: SkyWatcher APO ESPRIT 120 / x0.77 Reducer SkyWatcher / QHY 268 mono / Chroma Ha 5nm 36mm / Chroma SII 3nm 36mm / Chroma OI...
16 days ago
Both posts seek help resolving conflicting technical specifications for astrophotography equipment configurations.
EdgeHD 8 Focus Point Moving
Hello! Curious if anyone can assist here. I have an EdgeHD 8 using a ZWO EAF. Been using it fine for well over 2 years now and everything has been fine until recently. It can’t seem to find focus anymore using Nina/Hocus Focus. What happens is the fo...
19 days ago
Both posts describe technical problems with astrophotography equipment focusing systems.
