Colimation, tilt or?????
9 replies438 views
Christian Bennich avatar
Hey
I have recently acquired a TSGPU Coma Corrector for my 200PDS Skywatcher Newtonian.
My first test with it is here - https://www.astrobin.com/full/fewi16/B/, and I have nice stars, I think.
However, I see some larger stars with diffraction spikes "leaning" toward the middle of my image.
Does that home from bad collimation, tilt or.....
Any input or suggestions would be greatly appreciated.
deleted avatar
Could you post a raw unprocessed sub in this thread?   Doesn't have to be the actual raw file but export a raw sub as jpeg and just paste it here.  It's hard to tell from a processed image.
Well written Concise
Jan Schubert avatar
Hey Christian,
For me, the adjustment looks pretty good at first. It is difficult to judge, you should look at a picture without guiding influence,( Short exposure with high Gain/ISO).
The stars are a bit blured, this could be due to seeing or a less than optimal focus point -> Do you use a Bathinov mask or a Autofocuser?
The slightly frayed part of the stars are reflections: From the main mirror: you can have a ring printed/buy it or blacken the edge of the mirror. Or from the sec. mirrors, which are usually not colored at the factory.
CS Jan
I am using an autofocuser - I have considered a Bathinov mask as I think it's faster. The night imaging NGC281 was the first time with my Coma Corrector and it's absolutely possible that the focus has not been perfect.
 I don't think I have ever hear about this: "From the main mirror: you can have a ring printed/buy it or blacken the edge of the mirror. Or from the sec. mirrors, which are usually not colored at the factory."
Will definitely look into that - I guess it's Mirror Flocking - correct?
John Hayes avatar
I see a number of things.
1).  Your stars are mostly round from corner to corner, which indicates low coma.   That’s good.
2).  Overall your image shows soft focus.  That’s not so good.
3).  To my eye, it looks like the stars are more defocused on one side of the image compared to the other, which indicates possible sensor tilt.
Here is what I recommend:
1).  Point at a dense star field — like in the Milky Way.
2).  Use a B-mask to precisely focus on a bright star in the center of the field
3).  Start out with short exposures (~5-10s)  so that you can access focus from corner to corner
4).  Use a tool such as FWHMEccentricity in PI to look at the FWHM across the field to see how to adjust sensor tilt
5).  Once you have tilt corrected, use longer, well guided exposures (~ 180s) to look for coma in the corners of the field.  The stars should look round and equally small into the corners of the sensor.
6). Forget about the diffraction patterns.  The things that they might indicate are mostly irrelevant to the basic alignment that you are tying to do.
Well written Helpful Insightful
Wei-Hao Wang avatar
Those kind of pointy star spikes are often caused by some form of mechanical vignetting. If the mirror holder is not completely round, or some mechanical element in the OTA can obstruct some of the light path of off-axis light, this can happen. There can be other reasons though.
Jan Schubert avatar
Christian Bennich:
Whart i mean was a ap.erture Ring for the main mirror: https://teleskop-austria.at/Blende250#m
a the end of tommy ´s Newton Primer, you can find some problems and their solutions. https://teleskop-austria.at/information/pdf/FN25010c_Photonewton_Justage_Primer.pdf
Jan Schubert:
Christian Bennich:
Hahaha, OMG I haven’t read such a long document in German for some time 👍
Thank you for sending it over 🤪
deleted avatar
Christian Bennich:
Hey
Absolutely!!
Here is an export of the "raw" image - only stretched with STF - https://drive.google.com/file/d/1o5vem01hP4iDrkXCGc1tWDSuV9N7otyb/view?usp=sharing
The stacked raw xisf file - https://drive.google.com/file/d/1BZGyimOsMBC-vDiM_OYYaZS8dPR7zzkS/view?usp=share_link
I see what you're saying about the spike lean.  I'd check collimation first then tilt down the image train, scope>camera and everything in between.
Skywatcher coma corrector and zwo filter wheel back focus distance
I'm trying to get the back focus sorted on coma corrector. My equipment is a Skywatcher 200PDS with the 2" coma corrector from Skywatcher. I'm using a ZWO filter wheel, ZWO filters and a ZWO ASI1600MM camera. I currently have it set up w...
Skywatcher 200PDS with coma corrector showing similar edge star issues.
Nov 24, 2021
HOTECH CT Collimator and Edge Hd 8
Hello, I recently purchased the edge hd 8 and must have bounced around while being shipped because it was out of collimation from the get go. I decided to buy the HOTECH advanced ct laser collimator to help address the issue. After reading a version ...
Discusses collimation issues with telescopes; directly relevant to author's collimation concerns.
Nov 11, 2024
Help request for star shape diagnosis
Dear fellow astroimagers, A few weeks ago (not to say months or "ages"), I changed my main imaging camera. I swapped my trusted ASI294MC Pro for a Touptek 2600mm. I ran some test and the camera appears to work fine. However, I have persisti...
Addresses star shape diagnosis problems; author experiencing star shape issues needing diagnosis.
Dec 15, 2024
Samyang 135mm f/2.0 – Sensor Tilt or Another Bad Copy?
Dear Samy Users and Tilt Experts :-) To enter the world of wide-field astrophotography, and after reading so many positive reviews about this lens, I decided to pull the trigger—along with the Astrodymium kit, where I included the autofocuser and a g...
Covers sensor/optical tilt problems affecting star appearance; relevant to author's diffraction spike issue.
Feb 2, 2025
