I don't set any dial on mine even before I used Polemaster.
The main thing is you need to point the mount at the polar axis, everything rotates around it includes Polaris. Ignore all the dials.
Just find out where Polaris is around the True pole and get Polaris on the circle in the same place.
Think of the circle as a clock face, but don;t read the dial as such.
I then use Polarfinder which when installed on your computer needs to be set to your location and time. It will then tell you where polaris will be at any given time:
I think Ioptron do an app you can down load, it will be something like this, unfortunately this picture I found doesn't show Polaris, but hopefully you'll get the idea.
Wherever Polaris appears on your App, put it in the same place in your polarscope by adjusting the Alt/Az and latitude bolts.
Carole
