RCC - Can't eliminate light swirls on M101
3 replies147 views
Glenn Silverman avatar
M101: Pinwheel Galaxy
I can't seem to clean up the light swirls and gradient anomalies in this image of M101, despite some aggressive work in GraXpert  and HT in Pixinsight. Is there anything else I can do or is this a problem in my image train?
Any help is appreciated.
SemiPro avatar
The data itself does not look that bad considering it came from San Francisco.
I think your first problem is a lack of certain calibration frames. Did you take darks? Flats? Flat darks or bias frames?
Did you do any colour calibration? After you remove the gradients, you can run background neutralization, and then some color calibration. Since you are using a OSC camera, you can use SCNR to remove some or all of the green depending on your tastes.
Jeffbax Velocicaptor avatar
Hello. I think the main issue Comes from the flats. You should check them.
JF
I took flats and biases for calibration. I think my flats may be off.
Can we somehow Remove this weird Lightning From The Image?
Hello and welcome! I would like to ask everyone who uses Siril to process their astrophotography images: Is there any way to remove lightning artifacts from an image? This issue is really frustrating for me. I usually work hard to bring out the detai...
Addresses artifact removal techniques in astrophotography processing software.
Feb 19, 2025
Reflections (?) with all filters / images on QHY600M
Hi all, I posted previously about a "smudge" I was noticing on all of my flats with all filters. The smudge appeared to calibrate out in a few test images, so I went ahead and shot 40 hours of the Ghost of Cassiopeia. Unfortunately, after I...
Discusses calibration issues affecting image quality across multiple frames.
Oct 27, 2024
