IR light leak - can it be removed with dark frame calibration?
1 reply122 views
RammaN avatar
I have a Sony a7r2, there is a IR sensor in the camera that times the shutter. This bleeds IR light into every frame. To me it looks consistent in each frame.
  With being consistent, can i remove this signal with dark frames? Will i lose actual light frame signal?
In principle you should be able to remove it with the right master dark frame. And you wouldn't lose any signal in the process (at the expense of a slight increase in noise).
Well written
What reasons could affect Flat Frame performance?
Dear Friends, I require assistance with flat frame acquisition. It looks like my flat frames overcorrect the images and specifically in the green channel. I dont understand what the problem is! I had this issue before but usually the problem was ligh...
Dark frame subtraction removes consistent noise; flat frames correct vignetting and dust artifacts separately.
Feb 1, 2025
