SVX080T-3SV with the Starizona Apex ED .65 reducer??
8 replies220 views
MikeY_Astro avatar
I have a SVX080T-3SV on order, and I'm wanting to use it with the Starizona Apex ED .65 reducer. Is anyone using this combination? If so, what are your thoughts on it and do you like it?
Thank you.
Well written
Glenn Diekmann avatar
I have that combination and I do like it. I think it works well with 4/3 sensors but one does start to see corner aberrations with larger sensors. You can see some of my images in my gallery. Best, Glenn
Well written
MikeY_Astro avatar
Thanks Glenn - I'll take a look at your postings! I would be using it with the ASI2600, so might not be the best of fits..
Well written Respectful
I’m planning to use it with the same chip (QHY268M) during the summer. That reducer makes the scope quite fast at f/3.9. I’m thinking the corners might look decent enough when corrected with BlurXTerminator. We’ll see.
Best,
Glenn
Well written
MikeY_Astro avatar
Yeah, I was liking the speed and FL it would provide. Forgot about BXT! It might well be able to correct the corners if its not too bad.
Anthony Quintile avatar
I have that combo and it works well with an APS-C sensor, but you really need to fine tune the backspacing carefully. Fractions of a millimeter seems to make a difference. Being able to shoot at at F/3.9 with the Stellarvue astrograph is a pretty sweet option.
I've only shot one image with it. I have several scopes and I tend to gather a lot of data so I just haven't had an opportunity to come back to that combo again yet.
Here's the image: https://www.astrobin.com/h4t1r8/H/
This was shot before I really dialed in the backspacing, and I did use BlurXTerminator on it which helped the stars in the corners quite a bit. I am still not 100% happy with the stars in this image, so I may revisit the processing on it at some point.
I highly recommend anything from Starizona, and especially this reducer.
MikeY_Astro avatar
Anthony Quintile:
That turned out quite nice! OK, I'm sold.... I don't mind cropping out a bit if I HAVE to, but looking at your image, I'm game to get the reducer. Imaging and processing wise, I'm nowhere near your or Glenn's level so I'll likely be happy! Thank you!
MikeY_Astro:
Anthony Quintile:
Thanks @MikeY_Astro ! You'll love that reducer but, like I said, spend some time dialing in the backfocus. I have found good luck just making sure the math on my spacers adds up, but it can never hurt to confirm star shapes in the corners and add or subtract a shim to see if they improve.
Helpful Concise Supportive
MikeY_Astro avatar
Anthony Quintile:
MikeY_Astro:
Anthony Quintile:
Thanks for the tip Anthony. I've yet to receive the scope, about a month out I believe, but just ordered the reducer (stock has a habit of disappearing). I'll definitely do my best with the backfocus.
Starizona SCT Corrector IV - 0.63X Reducer / Coma Corrector (Backspace requierments)?
SO I have an older C8 and I was encouraged to invest in the Starizonia .63 reducer. Info I found was to establish a back space of 90.3 mm "but at 90.3", the telescope does not focaus clearly. The ASIair can't establish the scopes focal ...
Discusses Starizona reducer backspace requirements, directly relevant to your reducer compatibility question.
Dec 22, 2024
