Piers Palmer avatar
Last night was my first night with my new Vixen SD81S II and I was very excited that it was meant to be clear all night. Of course, it wasn't clear all night and actually started raining at 4am (thanks rain alarm app!). As a result, I only managed to get 22 x 180" subs, which I've stacked in DSS using x20 flats and a master dark and master bias from earlier this year.
After processing in Pixinsight; DBE, ABE and a photometric colour calibration (I'm still downloading the catalogues for SPCC), I got this (tiff file here
There's diagonal banding across the image; what have I done wrong?!
Short answer: don't use DSS, at all. Do it again, all in PI.
Piers Palmer avatar
But I'm 52…I might only have 30 years left to live. Is there time?
Actually, I did try that first but it was giving me an error message about compatibility…or something. I shall try again this evening.
Jonny Bravo avatar
That's an artifact from running DBE with low sample rate data. Try this:
Hopefully it'll get rid of the issue for you
Piers Palmer:
But I'm 52...I might only have 30 years left to live. Is there time?
Actually, I did try that first but it was giving me an error message about compatibility...or something. I shall try again this evening.
Take heart. I'm 61-ish and still learning...
If PI complains of something is best to take heed and figure out what is wrong. If you still have the flats and dark as well as the raw lights you can do it all over again. I mean, it is just 22 of them and clouds are forecast for weeks ahead of us.
By the way, I don't think it is the sampling, it is the flat fielding and using DSS. Don't use tiff either. Use 32 bit .fits or .xisf (better). Good news is that the banding won't be of much relevance once you get additional exposures.
Helpful Respectful Supportive
Piers Palmer avatar
Jonny Bravo:
That could come in useful considering my weather!
Piers Palmer avatar
Piers Palmer:
Quite right! I’m currently shooting new flats and darks just to have a clean starting point.
Strangely, the flats shot with my Lacerta flat panel show horizontal banding except at the lowest brightness. I’ve never had a problem with it before and there's no strobing of the light when viewed through my phone’s camera (which has show strobing with other set ups). I’ll see how I get on!
Piers Palmer:
If it shows banding at higher brightness then the issue isn't the brightness per se is the flickering (or strobing). Increase the exposure lengths to 2-3 seconds and add diffuser screens in between to dim the panel brightness, if needed. Personally I use sky flats whenever I can.
Piers Palmer avatar
I thought the whole point of a led flat panel was to give a uniform non-strobing light. I’ll try the sky method next time it’s not raining. I might be some time.
Piers Palmer avatar
Actually, the banding happened when the light panel was powered from the asiair. I then tried powering it directly from my portable battery and no banding at all.
Odd, but workaroundable.
Piers Palmer avatar
I think I did everything right.
It's certainly a lot better, and it'll do for around one hour of integration.
Djennings avatar
Yup, that last photo looks a lot better. I see no banding as I did in the first shot.
BTW, I'm 62 and still learning as well. With the will of God, hope to live a little longer to enjoy all his handy work in the skies.
Clear skies,
DJ
PixInsight -- separate flats for different filters?
I tried PixInsight for the first time tonight for stacking and was quite impressed. I was using the WeightedBatchProcessing script and really liked the way that it automatically split all my subs by filter and created master stacked images by filter ...
Not relevant — discusses banding issues, not flat frame handling.
Nov 11, 2021
[RCC] Strange artifacts in long exposure image
Not sure if this is the right place to post an image which is giving me a headache. I have recently started to take longer exposures because my object, SH2-129, is very weak in OIII. Here is my equipment: Takahashi Epsilon 130DASI 6200MM camera with ...
Diagonal banding artifact; matches author's potential image quality issues.
Sep 4, 2021
Flat Calibration Problem
Hi everyone, I'm having an issue with flats/calibration in my setup. My setup consists of a Carbon TS Newton 200/800 with Starizona Nexus (effectively 200/600), QHY ImageTrain (QHY 268M with QHY CFW), and AstroWanderer Rotator. A screenshot from ...
Flat calibration issues relevant to author's stacking workflow with flats.
Mar 11, 2025
M33. Should there be any green in the image at all?
Especially since the introduction of SPCC colour calibration into PixInsight I have given up using colour noise reduction tools to remove green pixels from images – because it ought to be unnecessary and will only alter the colour balance. Howe...
SPCC colour calibration in PixInsight matches author's post-processing technique.
Jan 7, 2025
