Ben:
@Rick Veregin I have a Nikon D810A and a 600mm F4 lens, and 2" SVBony 7nm Ha and OIII filters. My home town is coastal and I evaluate the skies as Bortle 7 when humid to a good Bortle 6 when dry, so not too bad but yeah humidity's a pain.
Seeing the previous messages about the Optolong filters, what are the gains if tomorrow I start imaging with a L-Ultimate (or Extreme) at F4 over the 7nm H/O? Is it "just" that a single duo band session doubles the imaging time with obvious gains in terms of integration, and better background "management", or there's something more subtle going on which I have not grasped?
Also, I do notice a small difference in focussing between Ha and OIII and wonder if a L-Ultimate would impact "sharpness" by forcing me to focus "good enough" for both B and R channels at the same time?
Thanks
I am assuming you mean that you currently use separate Ha and OIII filters with your Nikon camera, and are wondering the benefit of going to a duo band, where you collect both Ha and OIII at once.
Say you do one hour each for Ha and then OIII. And say the signal from the target is the same for Ha in R, and OIII in B and G, say 1000 photons/hr.
With the Ha filter in place you get R pixels=1000 photons, but G=0, B=0. With the OIII filter in place, R=0, G=B=1000 photons. After two hours R=G=B=1000 photons.
Say you capture the same two hours with L-eXtreme duo-band (about the same efficiency and contrast as you Sony filters as they are all 7 nm bandwidth).
You get R=G=B=2000 photons. So yes, you get twice the signal, and your S/N improves by sqrt(2)=1.41! Your background noise is thus improved dramatically. All this is the benefit you get.
However, your background itself is just as bright relative to the image signal, you are collecting twice the background as well as twice the signal. So this won't help contrast and gradients. Contrast comes from how narrow your filter is to block LP. I find that the L-eXtreme for me in Bortle 8 gives a nice background generally, no bad gradients, most of my gradients then come from poor flats. and I'm good now with my light-panel flats, I have a procedure that works well.
There is now an L-Ultimate which is 3 nm duo band, which will improve contrast and background LP. But at f/4 it might start cutting into your signal, as the bandpass changes as f-ratio decreases, so one can lose some signal. So not sure how to advise you there, it may still be better than the L-eXtreme for contrast but you will lose at least some signal, just not sure how much you lose for your setup. And it is pricy, I don't see myself going that way, happy at L-eXtreme.
L-eNhance is much broader bands, so contrast is degraded, though you get the same throughput advantage. I find this works well as a simple LP filter, for broadband targets like galaxies for example.
The difference in focusing is because your two filters don't have exactly the same refractive index and thickness, small variations there change your focus slightly when you change filters--the filters are not parfocal with each other. The duoband is one filter, so you don't have to worry about this effect. If your lens is poor quality with poor color focus, that would of course show up as a problem, but assuming you have a good quality lens, I don't see an issue.
Hope this helps.
Rick
