Jerry Gerber avatar
Last night I was imaging and guiding was going great, no issues.  I had ASIAIR Plus 2.1 all set properly to engage the auto meridian flip.  But when my object transited across the meridian, the flip didn't happen.   Somehow the mount didn't get the message.  I am using the ZWO AM5 mount with the ASIAIR, which I've been having successful results with.
I suspect it might have to do with daylight savings time.  I've always thought DST was one of the most idiotic ideas ever to exist, but now, I have another reason to dislike it because I can see it's impacting imaging.   I know my settings in ASIAIR are correct regarding my longitude and latitude, and the time was correct well.  ASIAIR was reporting that my mount's time was exactly one hour behind what the ASIAIR was showing (and the tablet's OS) which is what ZWO says is supposed to be the case.
So I have no idea why the flip failed.   I did the flip manually and continued to image but I'd like to know how to get the automatic flip working again.
Jerry
Quinn Groessl avatar
I don't know if they fixed it since I last live stacked, but I know whenever I live stack it doesn't flip, but if I'm imaging in autorun or plan mode it does.
Jerry Gerber avatar
Quinn Groessl:
I don't do live stacking, so that probably isn't the reason.
Need help with the Automatic Meridian Flip
I have been having many problems during aquisition of images when the meridian flip occurs. I have looked at some you tube videos to see where my settings are different. I thought I had everything correct before imaging the Eagle Nebula. Set it up fo...
Directly addresses meridian flip acquisition failures and system reset issues.
Jun 28, 2021
NINA and Daylight Savings Time
Wouldn't you know just when I am ready for first light at my scope's new dark sky site, it would be on the day DST begins. According to Time&Date.com, astronomical twilight ends tonight at 20:39. But NINA is saying astronomical twilight e...
DST may cause meridian flip failures with ASIAIR and ZWO mounts.
Mar 9, 2025
