Hello,
I recently bought an LRGB Pro set from Antlia, 1.25" mounted in a ZWO wheel on a new APO 100mm f/5.8 refractor. When making focus on the Luminance filter every thing was fine with pinpoint stars. I then launched a test series of LRGB images and two hours later I had a big suprise : the green and blue images were slightly out of focus and the red ones even strongly (you start to see "donuts" on the star disks…). This is not a question about temperature or problems with a loose focuser train as the L after the RGB were normal again and there is a brutal defocusing observed from the last L to the first R in the series. It looks like these filters are not parfocal which would be the first ever I used (I had Astronomik, Astrodon, Optolong). They are supposed to be parfocal even if we know that some times a very slight adjustment might be necessary. Does anyone here has faced a similar problem ?
Thank you very much in advance,
Andreas
Andreas
