jmdl101 avatar
Anyone else seeing halos in the blue and green channels? I now have halos with two different scopes, and they aren't even that bright of stars.
Marc V avatar
Which kind of filter? Some Optolong filter do halos…
jmdl101 avatar
Marc V:
Which kind of filter? Some Optolong filter do halos...
This is the Askar 6nm D1 and D2 colormagic filters, thought that was the title of this forum.
And of course it won't let me edit the first post to clarify.
Marc V avatar
Marc V:
You are right, I haven't see the forum title, I click directly on you post title.. sry...
Good luck with you investigation.
jmdl101 avatar
Marc V:
Marc V:
Yeah, I notice that it doesn't really show up very well, I may end up deleting the post and remaking it since I can't edit the first post for whatever reason.
Green stars...!?
While processing M4, something strange happened. There appear to be two distinctly green stars. I've tried different color calibration technique, but all give the same result. Also looking at signal in individual R, G and B stacks, it is clear th...
Color channel processing issue similar to halo problem with stars.
Jul 26, 2024
How do I reduce misty glow around stars?
Last night I shot M34 as I fancied trying to capture some of the faint tiny galaxies nearby too. I've processed the frames and it resulted in this I rather like it, but I've been wondering if I'd like it more without the misty glow around...
Directly addresses misty glow/halo artifacts around stars in astrophotography.
Oct 4, 2024
Does anyone know what this aberration is from?
Hi Everyone, I've been dealing with this aberration for some time now and can't seem to figure it out. This is taken with an ASI6200MM with OAG, filter wheel and Chroma filters. I get the same aberration for a particular target regardless of ...
Discusses optical aberrations that could cause halo effects in images.
Nov 13, 2024
