Patrick Graham avatar
Does anyone have any guidance on how to recombine an image after using the StarXterminator process.  I successfully created a starts image only and was able to reduce the number of stars without creating artifacts.  How to reintegrate the "reduced star" image  back into to the subject image is  not known to me.  I think it might be with Pixel Math but I'm not experienced enough yet to know how to use it.
Also,  any tips on where to insert this into the processing flow.  After integration:  DBE, NoiseXterminator, BlurXterminator, GHS stretch, Curve Transformation (saturation and color enhancement).
Thanks in advance
Patrick
Mr.D avatar
Hello Patrick.
Yes, Pixelmath is used to combine two images. Give a short whIle and I will post instructions on this subject. ( I am not near my Pixinsight computer at this time)
Paul Baker avatar
Hey Patrick,
I found this little formula some time ago and use it to either remove stars using the pre- and post- StarXT images. I have found it works really well.
So process with Star XT to generate the Starless image, this gives PostStarXT. Then plug the Pre- and Post- images into the Pixelmath formula as follwos:
For generating 'star mask' with PixelMaths:
~((~Pre-StarXT)/(~PostStarXT)) - this gives the 'Star Mask'
The play around with the 'Star Mask" to get colour and stretching right.
The recombine the 'Star Mask' back with the Starless image again using the following PixelMaths formula:
For combining stars back with PixelMaths:
~((~PostStarXT)*(~Star Mask)) with Create New Image
Re where to insert it, I usually do it just prior to stretching.
Give it a go.
Cheers
Paul
Thank you, Paul!!   This really clears it up and removes the roadblock I've been running against.   I'll work on my image with your technique and see what comes out!   I  appreciate you sharing this.
Clear Skies!!
Patrick
jeffreycymmer avatar
I use the Blend script using the Screen method to blend a starless image with the stars image.  BlurXTerminator is pretty good at reducing star sizes without separating out the stars.
Jeff
Jeff, thanks, too, for your input.   I didn't know about the Blend script and will play around with that, too.
Clear Skies!
Patrick
Rob Foster avatar
I use this method in Pixelmath and it works very well, which is in fact, the screen blend process in Pixelmath form:
combine(ImageX,ImageY,op_screen())
I cut and paste that formula into the Expression Editor, then find the two images I am trying to combine from the picklist on the right.  Simply replace ImageX with of your images, and ImageY with the other.   I then go back out of expression editor, and select New Image as the destination; drag the triangle to either image and you'll have your combined image!  By creating a new image, you can go back and tweak your original images and just keep recreating new versions.
As far as when, I like to separate in the linear state (though have experimented with both), that way I can clear up some of the noise before stretching; as a Canon DSLR user, I also use the Canon Banding Artifact script on the starless image far more effectively than the combined image. This also allows me to stretch stars and starless fields separately and I can pay much better attention to star color/saturation/cores.  I find I have to use HSV Repair far less often when I stretch the stars separate from the non-stellar images.  I don't recombine until both are processed in the non-linear state towards the end. Usually the only thing I will do after combining is tinker with star reduction using Bill Blanshan's formulas.
Clear Skies!
Rob
Helpful Insightful
Rob, thanks for the information.  I had no idea there was a Canon Banding Artifact script.   I just didn't know what to look for among all the script sections.  I'll definitely give that a try too.   Lots of experimentation to be done!   Again, thanks for the kind advice.
Patrick
Rob Foster avatar
Glad to help! The thing with that script is always check the box to Protect Highlights and to orient the bands horizontally for the script to work; sometimes images need to be rotated for the script to work, then I rotate back. With an image with bands but a full starfield, you will get some artifacts in line with bright stars/objects, so the I have found the script is way more useful on the starless images with far fewer artifacts. I'll sometimes run it once or twice.  Good luck!
MannyS avatar
When I process  JWST data on PixInsight, I get dark dots in the middle of stars when I use StarXterminator.  What causes this, and how do I a) fix it, or better yet b) avoid it.
Christian Koll avatar
Patrick,
this very topic is outlined in great detail by Russell Croman, himself, here:
https://pixinsight.com/forum/index.php?threads/unscreening-and-re-screening-recombining-stars-with-starless-images.18602/
Chris
PS: I do the non-linear processing in Photoshop - there you just set the star layer to blending mode "screen" - that's it.
Is There Any Method To Get Rid Of Artifacts?
Unprocessed Image Of Andromeda Galaxy https://imgur.com/a/98IUK1g Hello and welcome. I'd like to ask everyone who is using Seastar or any method to get rid of all of the artefacts in their deep sky images. I have a pretty good image I made with m...
Discusses StarXterminator and artifact reduction methods for astrophotography images.
Oct 1, 2024
Blotchy images after noise reduction
I've noticed lately I struggle with blotchy images during processing. Specifically after using NoiseXTerminator. You can see what I'm referring to in the top left corner of the image below. I am using a ZWO ASI2600MC, with an HaOiii dual-band...
Addresses blotchy artifacts after using NoiseXTerminator, similar processing tool issues.
Oct 16, 2024
Can We Process Astrophotography Images Better Without Starnet?
I’m currently experiencing some issues with Siril on my new PC, which has been quite frustrating. In the past, I primarily used star processing to focus on the object itself, and I had no problems with Siril. However, I now need to figure out how to ...
Explores star processing alternatives and image processing workflow optimization techniques.
Dec 28, 2024
"Optimizing My PixInsight Workflow for Deep-Sky Imaging: Insights Needed!"
Hello everyone,I would like to ask for your help in refining my deep-sky processing methods. I have been processing my images with PixInsight for about two and a half years, and since then, I have tried to improve my workflow with each processed imag...
Covers PixInsight workflow optimization including image recombination and processing flow sequencing.
Jan 7, 2025
