Linwood Ferguson avatar
I am not happy with this result and I think I know why, but could use any criticism.
https://www.astrobin.com/0zrmfg/
This is the Witch's Head and includes Rigel.  Most of it was shot from a Bortle 7 location, and the resulting stacks had very, very little nebula detail.  I managed to get one night at a Bortle 3 site (about 5.5 hours, it is setting early) and that helped bring out the nebula, but I shot all luminance that night and the R, G, and B stacks remained very poorly defined.
The result, for whatever reason, has some poorly defined stars.  I saturated them quite strongly to bring them out (an earlier version in a small group received universal comments that the stars were not prominent enough), and there is patchy nebulosity (at least I hope it is real) causing large halos on some stars.  Further complicating stars the NP101is did not do well in the corners (and yes, have spent may days and hours adjusting tilt and backfocus, this is about as good as I can get it).  The star shapes are bad enough this won't even plate solve on astrobin, by the way.
Anyway... this is the second attempt at processing, and for the record I was aiming at something more artistic than scientific.  I left a lot of glare on Rigel (though toned it down with some local curves on it), and emphasized color at the expense of some star color accuracy.  And yes, for the northern hemisphere purists it is upside down -- but I wanted it to be a face in starlight!
The processing was fairly standard in PI, stack and drizzle R, G, B and L, stretch separately, combine, etc.  I used BlurXTerminator to try to get better star shape with mixed success (I do not think it recognized the stars as stars in the corners).  I had some 15s R, G, B stars I was going to use for replacement but I could not remove stars from the main image (both starnetv2 and starXTerminator left LOTS of them in, again I think from poor shapre).  I used the LRGB combination process to increase saturation more than I normally would, for some artistic coloring.
My thinking is the main thing this needs is more low bortle time in RGB and a fresh processing run.  While the detail from one night of good Luminance brought out detail, I think the mediocre R, G, B failed to get any color in the nebulosity really, and also has affected star colors so that my addition of saturation made them bloat.  But... that's a theory I will only be able to test next year.
I welcome other criticism and suggestions.
Linwood
Nice example of high order coma. I would stick to RGB only from a dark site and try to bring down the field a notch or two.
Interesting, so forgo more (or any Luminance) and get a night or three of RGB and use a synthetic luminance?
I can't reduce the field of view and get both in, this is virtually uncropped.  I could (and might next year) do a mosaic with my 152, which has none of this star distortion in the corners.  But it's likely a 2x2 even with a reducer which makes it a MUCH longer shoot.  Yeah... maybe 1x3 would do it, 1x2 I have no, or negative, overlap.
Linwood Ferguson:
Why bother with L? Go stright for pure RGB and colours will litterally jump at you. To be perfectly honest with NGC1909 you would want something like a 200mm with an APS-C camera or a 300mm with a FF. I suspect my 300mm would do a better job than the NP with a FF, but here we are and we got to do with what we have...
Linwood Ferguson:
I generally do not use L, but in this case it was the most efficient way to collect enough data in one night (well, two, I thought I might get enough at home, but it was of negligible benefit).  I have lots of wonderful camera lenses -- all FE mount Sony's that are too short of flange depth for use with a real astro camera, and I'm not going back to an MILC body for astro, too many quirks.
As you say, we do with what we have.
Stars with 'holes'
I took two nights photos of the Dolphin Nebula and stacked using WBPP. It seems that a lot of the stars, anywhere in the image, have a 'hole' in the middle… What could be the cause of this? Even though the FRA300 is petzval, stars show ...
Stars with holes may indicate stacking or processing issues affecting image quality.
Jan 9, 2025
[RCC] Soul Nebula: Where is my OIII?
Hello everyone. I recently purchased my first dedicated astronomical camera (Playerone Ares-C) and am finally starting to get some data that can be considered as such. After a few short acquisition tests, I finally managed to acquire a substantial da...
OIII channel problems similar to author's RGB stack definition issues.
Nov 3, 2024
Poor starfield.
When i get pinpoint stars at the center of the field, i get such a poor covering of the stars in the corners, I am using a full frame sensor canon EOS R6. Imaging the Western Veil nebula for context. The image is a stack of 109 x 60 seconds, so there...
Poor starfield coverage could relate to author's uneven nebula detail across image.
Jul 27, 2024
[RCC] NGC3718 - more „Pop“, better stars?
NGC3718 https://astrob.in/oiujzm/0/ Hello, I have combined data from last year (about 6 hours) and this year (8 hours) LRGB (3-1-1-1) for this target. All four days that I collected the data had subpar seeing (3“), so I know the amount of detail poss...
Discusses image processing workflow and seeking feedback on astronomical results.
Feb 16, 2021
M13
I have been trying for a long time to decide which version of my M13 I should call the final. I have dozens upon dozens of versions beyond what is posted on Astrobin. I am trying for a realistic look–so not too much saturation, as much resoluti...
Relevant for seeking criticism and feedback on image processing choices.
Aug 16, 2021
