Question about Star Alignment in Pixinsight
4 replies273 views
Jerry Gerber avatar
Tonight everything was going great until my headlamp batteries died and it was very dark while I was checking a cable.  I bumped a tripod leg.  So I polar aligned again and went to my target to continue shooting, but I noticed that the position of the new images after I polar aligned the 2nd time were not exactly in the same position as the images taken before I bumped the tripod leg,
Is this going to produce a headache for me when I try to register and align the images?   Which settings in "Star Alignment" should I pay attention to?
Thank you!
Jerry
Pistachio_Enjoyer avatar
Depends on how far off your later images are. When star aligning, you select a reference image and all other images are aligned based off of that. You might see your other images get clipped somewhat.
Steve Spring avatar
Hi Jerry,
So long as a fair proportion of your stars remain in the field of view then star alignment will probably handle it for you.
As @Pistachio_Enjoyer has said, choose your ref frame and run it. The results will explain everything.
Do you use dithering between shots?
If not you may have inadvertantly done your first dither, albeit by an uncalculated distance
Supportive
Monty Chandler avatar
Should be fine.  Set RANSAC tolerance to 3 or 4  and iterations to 3000.  Cheers
Jerry Gerber avatar
Great, thanks Monty, Steve and Pistachio Enjoyer!  The 113 subs all registered successfully.   Thank goodness for computers.  I thought that registration would only work if the stars were a few pixels off, but it's surprisingly far more tolerant than I thought.
Drizzle integration issue in PixInsight after two sets of images with different resolution have been previously correctly integrated
Hi everyone, today I’m presenting an issue I’ve encountered while trying to integrate two sets of images with different resolutions and original sampling in PixInsight: one taken with an ASI533MC PRO + 115/800 telescope and the other with a Canon 90D...
Addresses image registration issues when combining misaligned image sets from different sessions.
Dec 6, 2024
Polar align EQM-35, asiair problem
Hey everyone, after several attempts to figure out why I keep getting star trails and what's wrong with my alignment, I’ve decided to ask for help here. I’m trying to polar align my EQM-35 mount using ASIAIR. First, I manually aligned it using th...
Discusses polar alignment problems affecting image quality and positioning consistency.
Dec 21, 2024
Star Adventurer not holding polar alignment
Hi all! After one year of flawless use, I'm starting to have trouble with my Star Adventurer. On two of my last four imaging sessions, it's not holding polar alignment. I don't know what could be causing this, I follow the same workflow e...
Covers equipment failing to maintain polar alignment during imaging sessions.
Jul 10, 2024
