XTerminator for RGB stars ?
5 replies451 views
Thomas Ammann avatar
Hello - anyone using Russel Cromas XTerminator modules to prepare RGB stars before importing to an starless HSO image? What workflow? What results? Thanks very much
jewzaam avatar
Yes, and also StarNet v2 when it does a better job (depends on the data).
My process is to unscreen then rescreen after some processing of stars (color, saturation, reduce, etc).
https://pixinsight.com/forum/index.php?threads/unscreening-and-re-screening-recombining-stars-with-starless-images.18602/
Dale Penkala avatar
I use StarXTerminator pretty much exclusivly. I’ve used both starnet v2 and found for my data at least I have better results with it. Here is an example if your interested. https://www.astrobin.com/ejng9o/
Read down in the comments about my processing of the my star layer. This is how I process my star layer.
Here is another one as well. https://www.astrobin.com/full/4orxln/B/
Dale
Very interesting : gonna try your un- and rescreening process - thank's
Dale Penkala:
Dale
Beautiful stars ! thank's
Dave B avatar
I describe my workflow in detail in a comment reply on this image: https://www.astrobin.com/r6zmqj/F/
That was my first and only image processed with StarXterminator thus far, but it will definitely be my default workflow moving forward.
Any secret NR methods? Topaz Denoise? What is your method?
Hello all. know a number of you have had some experience with Topaz - can you tell me how you use it? is the Denoise in Photo AI or the Classic (standalone) version better? I don't think I can get a license for the standalone version because it&#...
Discusses noise reduction methods relevant to star preparation workflows.
Nov 27, 2024
"Optimizing My PixInsight Workflow for Deep-Sky Imaging: Insights Needed!"
Hello everyone,I would like to ask for your help in refining my deep-sky processing methods. I have been processing my images with PixInsight for about two and a half years, and since then, I have tried to improve my workflow with each processed imag...
PixInsight deep-sky processing workflow optimization aligns with author's needs.
Jan 7, 2025
Starry Background, Starless Nebula: My Latest Experiment
While experimenting with PixInsight, I stumbled upon something I’m calling “Mixed Stars.” Maybe someone has done it before, maybe not—but I just love how it looks! Essentially, I managed to add the stars only in the background while keeping the nebul...
Directly addresses starless nebula technique with separate star processing approach.
Dec 2, 2024
