Line artifacts in registax (stacked moon images)
5 replies377 views
vishal_toronto avatar
Hi everyone. New to Astro and imaged the moon with full frame mirrorless and stacked in autostakkert.
during the processing in registax it’s leaving these faint lines as it goes through the process.  I tried changing the process area which seemed to help but zoomed in there are still faint yellow lines in the image.  Does anyone know what could cause this?  I can see the lines appear in real time during the ‘do all’ sharpening.
it’s full frame and 45mp so it’s a large file (not sure if that’s relevant)
Steve Solon avatar
Hi Vishal,
I don't know that I see the lines you're talking about. The only faint lines visible in this fine image are the ejecta rays from Copernicus and Tycho, as well as other lines that exist on the Moon. Also, this image is a bit over-sharpened; whether or not this is producing something you're seeing is up to you, but for my money, this is a beautiful image. You might back down a bit on the first and second wavelet layers and see what happens. Beyond that, nice work, mate.
- - Steve
Well written Respectful Concise Supportive
Neven Krcmarek avatar
Did you try changing the wavelet filter to default?
Well written
Thank you both for the quick replies!
I’ll check if the wavelet filter was set at default and will back down on the sharpening thanks!
The lines appear at the bottom of processing area boxes as it goes through it’s sharpening.  I’ve zoomed in here to show you.
I (sometimes) got this lines using Gaussian Wavelet filter, it disappears when set to default. It's actually a bug in the Registax software that was never fixed. The sharpness is quite fine but now you have a lot of noise. Some sort of noise reduction would help smoothen things out a bit.
nonsens2 avatar
Hello folks,
I use registax for sharpening the solar system images with the wavelet filters and have to deal with the same issue. First, use the filter carefully. When they appear I use the denoise function of the filter and ususally get rid of these artifacts. Second, use the wavelet filter with care. Less is sometimes more. i usually use the linked wavelets. It's more tricky, but when you get used to it the results are quite good.
Greetings Nik
What Can Cause Pipp Software To Fail Processing Moon Images?
Hello and welcome. I'd like to ask everyone who uses PIPP to process their moon images in any category, ranging from normal full moon to lunar eclipse. Recently, there was a partial lunar eclipse that I captured with a Seastar telescope. Those im...
PIPP processes moon images; may address similar stacking/processing artifacts.
Oct 6, 2024
Artefacts in registered images....what am I missing????
Hi All I am imaging a dusty region, and when stacking, I can see that my flats have not correctly removed a particular artefact. Any input on what I might be missing here?? I cannot understand what I am not doing correctly to prevent this annoying ar...
Discusses artifacts in registered/stacked images; directly relevant to artifact problem.
Nov 28, 2024
Relationship between FWHM of the individual frames and FWHM of the final stack
I am trying to understand what's the relationship, if any, between the sharpness of the individual frames versus the sharpness of the final stacked RAW through WBPP. My latest image https://www.astrobin.com/full/q1t9sq/0/ has an average FWHM of t...
Addresses sharpness issues in stacking process; relevant to processing problems.
Dec 10, 2024
RCC - Moon - Horizontal Lines!
Hello Everyone, I took this along with many other AVI files and processed them in AutoStakertt and processed them in Gimp. I’m noticing these horizontal lines that you see if you zoom in closer. It’s easier to look at the terminator along the left si...
Line artifacts in registax (stacked moon images) — addresses horizontal lines in stacked/processed astronomical images.
Jun 20, 2021
